Sign "+" in $ARGn$
bamsas
Sign "+" in $ARGn$
Post by bamsas »
CentOS release 6.6 (Final) 64bit, manual install on VMware VM, Nagios XI 2014R2.0 - nothing special.
I developed script for Tomcat monitoring, it works from command line:
[root@nagios libexec]# ./check_bamsas_tomcat.pl -v -H hds1.prod.bamsas.com --port=8081 --url='/nagios.jsp' --name='Catalina:type=ThreadPool,name="http-nio-8080"' --attr='connectionCount+currentThreadCount+currentThreadsBusy'
OK - connectionCount: 8 |  connectionCount=8 currentThreadCount=161 currentThreadsBusy=2
I created Nagios command and service:
$USER1$/check_bamsas_tomcat.pl -v -H $HOSTADDRESS$ --port=8081 --url='$ARG1$' --name='$ARG2$' --attr='$ARG3$' $ARG4$ $ARG5$
and tried to use it with args:
$ARG1$ /nagios.jsp
$ARG2$ Catalina:type=ThreadPool,name="http-nio-8080"
$ARG3$ connectionCount+currentThreadCount+currentThreadsBusy
$ARG4$ -w 2048 -c 3072
Test check command returns:
Testing check from command line...
COMMAND: /usr/local/nagios/libexec/check_bamsas_tomcat.pl -v -H hds1.prod.bamsas.com --port=8081 --url='/nagios.jsp' --name='Catalina:type=ThreadPool,name="http-nio-8080"' --attr='connectionCount currentThreadCount currentThreadsBusy' -w 2048 -c 3072
OUTPUT: OK - connectionCount currentThreadCount currentThreadsBusy:  |
So, Nagios removed my "+" from $ARG3$
How can I resolve this issue?
jdalrymple
Skynet Drone
Re: Sign "+" in $ARGn$
Post by jdalrymple »
That's wicked strange:
[jdalrymple@localhost services]$ grep "+" /usr/local/nagios/var/status.dat
        check_command=check_dummy!0!this+that!!!!!!
        plugin_output=OK: this+that
What do you get if you fix it in the service description instead of setting it as an arg? I'm not sure where it's getting stripped.
bamsas
Post by bamsas »
Yes, that's really strange....
I activated service and applied configuration - it works as well. I see all 3 graphs.
[root@nagios libexec]# grep "+" /usr/local/nagios/var/status.dat
check_command=bamsas-check-tomcat!/nagios.jsp!Catalina:type=ThreadPool,name="http-nio-8080"!connectionCount+currentThreadCount+currentThreadsBusy!-w 2048 -c 3072!!!!
So, only one thing doesn't work: "Test Check Command" button. I will survive with it :-)
Thank you!
jdalrymple
Skynet Drone
Ahh - test check command should never be relied upon, too much mystical Internet junk at play. I was under the impression that it wasn't in play since we're in the Core forum section.
Locking it up OK?
bamsas
Post by bamsas »
Yes, looks OK: 3 graphs, 3 gauges - everything is on place.
Please lock it.
