This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
snapon_admin
Posts: 952 Joined: Mon Jun 10, 2013 10:39 am
Post
by snapon_admin » Mon Aug 31, 2015 10:54 am
so I came in today unable to access our Nagios server (could ping it, but the web URL wouldn't load and it was inaccessible via SSH). I had one of our VM admins reboot it for me and it came back up but the page only showed the "your databases are broke, run the database repair script" message all over the screen so I did that. After the script ran the DBs still seemed jacked so I applied a config which didn't fix it. So I then rebooted the server from an SSH session and it booted back up and that message was gone. now I'm getting this message:
SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_hoststatus'
I tried restoring from the most recent backup (yesterdays) and got this error at the end of the backup restore:
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
Error restoring MySQL database 'nagios' - check the password in this script!
What do?
Posts: 9190 Joined: Thu Oct 30, 2014 9:02 am
Post
by tgriep » Mon Aug 31, 2015 12:00 pm
Can you post the output of this command?
Here is another method of repairing the mysql database. You can try it to see if it repairs the database.
service mysqld stop
cd /var/lib/mysql/nagios
myisamchk -r -f *
service mysqld start
rm -f /usr/local/nagiosxi/var/dbmaint.lock
php /usr/local/nagiosxi/cron/dbmaint.php
Be sure to check out our
Knowledgebase for helpful articles and solutions!
snapon_admin
Post
by snapon_admin » Mon Aug 31, 2015 12:10 pm
[root@keno-ngos-01-pv nagios]# tail -50 /var/log/mysqld.log
150831 12:07:22 [ERROR] /usr/libexec/mysqld: Incorrect key file for table './nagios/nagios_servicestatus.MYI'; try to repair it
150831 12:07:43 [ERROR] /usr/libexec/mysqld: Incorrect key file for table './nagios/nagios_servicestatus.MYI'; try to repair it
150831 12:08:01 [ERROR] /usr/libexec/mysqld: Incorrect key file for table './nagios/nagios_servicestatus.MYI'; try to repair it
150831 12:08:18 [Note] /usr/libexec/mysqld: Normal shutdown
150831 12:08:18 [Note] Event Scheduler: Purging the queue. 0 events
150831 12:08:20 InnoDB: Starting shutdown...
150831 12:08:22 InnoDB: Shutdown completed; log sequence number 0 44253
150831 12:08:22 [Note] /usr/libexec/mysqld: Shutdown complete
150831 12:08:22 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
150831 12:08:46 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
150831 12:08:46 InnoDB: Initializing buffer pool, size = 8.0M
150831 12:08:46 InnoDB: Completed initialization of buffer pool
150831 12:08:46 InnoDB: Started; log sequence number 0 44253
150831 12:08:46 [Note] Event Scheduler: Loaded 0 events
150831 12:08:46 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.1.71' socket: '/var/lib/mysql/mysql.sock' port: 3306 Source distribution
running that alternate fix method didn't seem to fix it.
Post
by tgriep » Mon Aug 31, 2015 12:36 pm
Are you still having issues logging in to the XI GUI?
snapon_admin
Post
by snapon_admin » Mon Aug 31, 2015 12:39 pm
No I can log into the GUI, it's just all broken.
Post
by tgriep » Mon Aug 31, 2015 12:49 pm
Lets stop the nagios processes and run the repair again.
service nagios stop
service npcd stop
service nagios stop
killall -9 nagios
service cron stop
service mysqld stop
myisamchk -r -f *
service ndo2db start
service npcd start
service nagios start
service cron start
Let us know if this fixes it.
jdalrymple
Skynet Drone
Posts: 2620 Joined: Wed Feb 11, 2015 1:56 pm
Post
by jdalrymple » Mon Aug 31, 2015 12:51 pm
snapon_admin wrote: I tried restoring from the most recent backup (yesterdays) and got this error at the end of the backup restore:
Did you change the username or password for the nod db? We install it with a specified known set of creds that are in the backup script. If you changed either of those you might have to spruce up the restore script to match. Also - are you sure it wasn't blown up at the time that you tried restoring from? The weekend gives a lot of time at which it could have failed.
snapon_admin
Post
by snapon_admin » Mon Aug 31, 2015 1:00 pm
tgriep, no that doesn't appear to have fixed the issue. jdalrymple, I have not changed those passwords (at least not intentionally, I'm not even sure HOW to do that), and no I'm not sure that the backup from this weekend was before it blew up. It's actually quite likely to have been after if I had to guess. I have one other backup from last week that I can try.
Post
by tgriep » Mon Aug 31, 2015 1:06 pm
Before you try the restore, can you run the following and post back?
df -h
df -i
ps aux
snapon_admin
Post
by snapon_admin » Mon Aug 31, 2015 1:21 pm
[root@keno-ngos-01-pv nagios]# df -h
/dev/mapper/VolGroup-lv_root
97G 50G 42G 55% /
tmpfs 3.9G 0 3.9G 0% /dev/shm
/dev/sda1 485M 50M 410M 11% /boot
[root@keno-ngos-01-pv nagios]# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
6335472 158463 6177009 3% /
tmpfs 1006755 1 1006754 1% /dev/shm
/dev/sda1 128016 44 127972 1% /boot
[root@keno-ngos-01-pv nagios]# ps aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.0 19232 1424 ? Ss 09:43 0:01 /sbin/init
root 2 0.0 0.0 0 0 ? S 09:43 0:00 [kthreadd]
root 3 0.0 0.0 0 0 ? S 09:43 0:00 [migration/0]
root 4 0.0 0.0 0 0 ? S 09:43 0:00 [ksoftirqd/0]
root 5 0.0 0.0 0 0 ? S 09:43 0:00 [migration/0]
root 6 0.0 0.0 0 0 ? S 09:43 0:00 [watchdog/0]
root 7 0.0 0.0 0 0 ? S 09:43 0:00 [migration/1]
root 8 0.0 0.0 0 0 ? S 09:43 0:00 [migration/1]
root 9 0.0 0.0 0 0 ? S 09:43 0:00 [ksoftirqd/1]
root 10 0.0 0.0 0 0 ? S 09:43 0:00 [watchdog/1]
root 11 0.0 0.0 0 0 ? S 09:43 0:00 [migration/2]
root 12 0.0 0.0 0 0 ? S 09:43 0:00 [migration/2]
root 13 0.0 0.0 0 0 ? S 09:43 0:00 [ksoftirqd/2]
root 14 0.0 0.0 0 0 ? S 09:43 0:00 [watchdog/2]
root 15 0.0 0.0 0 0 ? S 09:43 0:00 [migration/3]
root 16 0.0 0.0 0 0 ? S 09:43 0:00 [migration/3]
root 17 0.0 0.0 0 0 ? S 09:43 0:00 [ksoftirqd/3]
root 18 0.0 0.0 0 0 ? S 09:43 0:00 [watchdog/3]
root 19 0.0 0.0 0 0 ? S 09:43 0:00 [events/0]
root 20 0.0 0.0 0 0 ? S 09:43 0:00 [events/1]
root 21 0.0 0.0 0 0 ? S 09:43 0:00 [events/2]
root 22 0.0 0.0 0 0 ? S 09:43 0:00 [events/3]
root 23 0.0 0.0 0 0 ? S 09:43 0:00 [cgroup]
root 24 0.0 0.0 0 0 ? S 09:43 0:00 [khelper]
root 25 0.0 0.0 0 0 ? S 09:43 0:00 [netns]
root 26 0.0 0.0 0 0 ? S 09:43 0:00 [async/mgr]
root 27 0.0 0.0 0 0 ? S 09:43 0:00 [pm]
root 28 0.0 0.0 0 0 ? S 09:43 0:00 [sync_supers]
root 29 0.0 0.0 0 0 ? S 09:43 0:00 [bdi-default]
root 30 0.0 0.0 0 0 ? S 09:43 0:00 [kintegrityd/0]
root 31 0.0 0.0 0 0 ? S 09:43 0:00 [kintegrityd/1]
root 32 0.0 0.0 0 0 ? S 09:43 0:00 [kintegrityd/2]
root 33 0.0 0.0 0 0 ? S 09:43 0:00 [kintegrityd/3]
root 34 0.0 0.0 0 0 ? S 09:43 0:00 [kblockd/0]
root 35 0.0 0.0 0 0 ? S 09:43 0:00 [kblockd/1]
root 36 0.0 0.0 0 0 ? S 09:43 0:00 [kblockd/2]
root 37 0.0 0.0 0 0 ? S 09:43 0:00 [kblockd/3]
root 38 0.0 0.0 0 0 ? S 09:43 0:00 [kacpid]
root 39 0.0 0.0 0 0 ? S 09:43 0:00 [kacpi_notify]
root 40 0.0 0.0 0 0 ? S 09:43 0:00 [kacpi_hotplug]
root 41 0.0 0.0 0 0 ? S 09:43 0:00 [ata/0]
root 42 0.0 0.0 0 0 ? S 09:43 0:00 [ata/1]
root 43 0.0 0.0 0 0 ? S 09:43 0:00 [ata/2]
root 44 0.0 0.0 0 0 ? S 09:43 0:00 [ata/3]
root 45 0.0 0.0 0 0 ? S 09:43 0:00 [ata_aux]
root 46 0.0 0.0 0 0 ? S 09:43 0:00 [ksuspend_usbd]
root 47 0.0 0.0 0 0 ? S 09:43 0:00 [khubd]
root 48 0.0 0.0 0 0 ? S 09:43 0:00 [kseriod]
root 49 0.0 0.0 0 0 ? S 09:43 0:00 [md/0]
root 50 0.0 0.0 0 0 ? S 09:43 0:00 [md/1]
root 51 0.0 0.0 0 0 ? S 09:43 0:00 [md/2]
root 52 0.0 0.0 0 0 ? S 09:43 0:00 [md/3]
root 53 0.0 0.0 0 0 ? S 09:43 0:00 [md_misc/0]
root 54 0.0 0.0 0 0 ? S 09:43 0:00 [md_misc/1]
root 55 0.0 0.0 0 0 ? S 09:43 0:00 [md_misc/2]
root 56 0.0 0.0 0 0 ? S 09:43 0:00 [md_misc/3]
root 57 0.0 0.0 0 0 ? S 09:43 0:00 [khungtaskd]
root 58 0.0 0.0 0 0 ? S 09:43 0:08 [kswapd0]
root 59 0.0 0.0 0 0 ? SN 09:43 0:00 [ksmd]
root 60 0.0 0.0 0 0 ? SN 09:43 0:02 [khugepaged]
root 61 0.0 0.0 0 0 ? S 09:43 0:00 [aio/0]
root 62 0.0 0.0 0 0 ? S 09:43 0:00 [aio/1]
root 63 0.0 0.0 0 0 ? S 09:43 0:00 [aio/2]
root 64 0.0 0.0 0 0 ? S 09:43 0:00 [aio/3]
root 65 0.0 0.0 0 0 ? S 09:43 0:00 [crypto/0]
root 66 0.0 0.0 0 0 ? S 09:43 0:00 [crypto/1]
root 67 0.0 0.0 0 0 ? S 09:43 0:00 [crypto/2]
root 68 0.0 0.0 0 0 ? S 09:43 0:00 [crypto/3]
root 73 0.0 0.0 0 0 ? S 09:43 0:00 [kthrotld/0]
root 74 0.0 0.0 0 0 ? S 09:43 0:00 [kthrotld/1]
root 75 0.0 0.0 0 0 ? S 09:43 0:00 [kthrotld/2]
root 76 0.0 0.0 0 0 ? S 09:43 0:00 [kthrotld/3]
root 77 0.0 0.0 0 0 ? S 09:43 0:00 [pciehpd]
root 79 0.0 0.0 0 0 ? S 09:43 0:00 [kpsmoused]
root 80 0.0 0.0 0 0 ? S 09:43 0:00 [usbhid_resumer]
root 110 0.0 0.0 0 0 ? S 09:43 0:00 [kstriped]
root 292 0.0 0.0 0 0 ? S 09:43 0:00 [scsi_eh_0]
root 293 0.0 0.0 0 0 ? S 09:43 0:00 [scsi_eh_1]
root 305 0.0 0.0 0 0 ? S 09:43 0:00 [mpt_poll_0]
root 306 0.0 0.0 0 0 ? S 09:43 0:00 [mpt/0]
root 307 0.0 0.0 0 0 ? S 09:43 0:00 [scsi_eh_2]
root 374 0.0 0.0 0 0 ? S 09:43 0:00 [kdmflush]
root 376 0.0 0.0 0 0 ? S 09:43 0:00 [kdmflush]
root 393 0.0 0.0 0 0 ? S 09:43 0:03 [jbd2/dm-0-8]
root 394 0.0 0.0 0 0 ? S 09:43 0:00 [ext4-dio-unwrit]
root 395 0.0 0.0 0 0 ? S 09:43 0:00 [ext4-dio-unwrit]
root 396 0.0 0.0 0 0 ? S 09:43 0:00 [ext4-dio-unwrit]
root 397 0.0 0.0 0 0 ? S 09:43 0:00 [ext4-dio-unwrit]
root 470 0.0 0.0 10908 1004 ? S<s 09:43 0:00 /sbin/udevd -d
root 670 0.0 0.0 0 0 ? S 09:43 0:00 [vmmemctl]
root 705 0.0 0.0 0 0 ? S 09:43 0:00 [hd-audio0]
root 793 0.0 0.0 10904 1036 ? S< 09:43 0:00 /sbin/udevd -d
root 821 0.0 0.0 0 0 ? S 09:43 0:00 [jbd2/sda1-8]
root 822 0.0 0.0 0 0 ? S 09:43 0:00 [ext4-dio-unwrit]
root 823 0.0 0.0 0 0 ? S 09:43 0:00 [ext4-dio-unwrit]
root 824 0.0 0.0 0 0 ? S 09:43 0:00 [ext4-dio-unwrit]
root 825 0.0 0.0 0 0 ? S 09:43 0:00 [ext4-dio-unwrit]
root 857 0.0 0.0 0 0 ? S 09:43 0:00 [kauditd]
root 1094 0.0 0.0 27664 848 ? S<sl 09:43 0:00 auditd
root 1110 0.0 0.0 249084 3912 ? Sl 09:43 0:01 /sbin/rsyslogd -i /var/run/syslogd.pid -c 5
dbus 1122 0.0 0.0 21404 804 ? Ss 09:43 0:00 dbus-daemon --system
root 1159 0.0 0.0 64400 1204 ? Ss 09:43 0:00 /usr/sbin/sshd
root 1167 0.0 0.0 22096 936 ? Ss 09:43 0:00 xinetd -stayalive -pidfile /var/run/xinetd.pid
ntp 1175 0.0 0.0 30720 2020 ? Ss 09:43 0:00 ntpd -u ntp:ntp -p /var/run/ntpd.pid -g
postgres 1350 0.0 0.0 214048 6180 ? S 09:43 0:01 /usr/bin/postmaster -p 5432 -D /var/lib/pgsql/data
root 1353 0.2 0.0 0 0 ? S 09:43 0:27 [flush-253:0]
postgres 1354 0.0 0.0 177060 1448 ? Ss 09:43 0:00 postgres: logger process
postgres 1356 0.0 0.0 214168 6112 ? Ss 09:43 0:01 postgres: writer process
postgres 1357 0.0 0.0 214048 1760 ? Ss 09:43 0:01 postgres: wal writer process
postgres 1358 0.0 0.0 214184 1952 ? Ss 09:43 0:00 postgres: autovacuum launcher process
postgres 1359 0.0 0.0 177192 1676 ? Ss 09:43 0:01 postgres: stats collector process
root 1437 0.0 0.0 79072 3364 ? Ss 09:43 0:00 /usr/libexec/postfix/master
postfix 1446 0.0 0.0 79324 3240 ? S 09:43 0:00 qmgr -l -t fifo -u
root 1447 0.0 0.1 337720 13832 ? Ss 09:43 0:00 /usr/sbin/httpd
root 1455 0.0 0.0 117216 1244 ? Ss 09:43 0:00 crond
ajaxterm 1472 0.0 0.0 168208 7712 ? Sl 09:43 0:03 python /usr/share/ajaxterm/ajaxterm.py --daemon --port=8022 --uid=ajaxterm
apache 1493 2.4 0.4 462048 36636 ? S 09:43 5:20 /usr/sbin/httpd
apache 1494 2.4 0.4 461700 36376 ? S 09:43 5:17 /usr/sbin/httpd
apache 1495 2.4 0.4 461660 36292 ? S 09:43 5:17 /usr/sbin/httpd
apache 1496 2.4 0.4 462204 36684 ? S 09:43 5:18 /usr/sbin/httpd
apache 1497 2.4 0.4 461544 36156 ? S 09:43 5:18 /usr/sbin/httpd
apache 1498 2.4 0.4 462204 36600 ? S 09:43 5:18 /usr/sbin/httpd
apache 1499 2.4 0.4 461692 36264 ? S 09:43 5:16 /usr/sbin/httpd
apache 1500 2.4 0.4 461708 36236 ? S 09:43 5:18 /usr/sbin/httpd
postgres 1501 0.0 0.0 215964 7144 ? Ss 09:43 0:07 postgres: nagiosxi nagiosxi ::1(53719) idle
postgres 1502 0.0 0.0 215964 7596 ? Ss 09:43 0:07 postgres: nagiosxi nagiosxi ::1(53720) idle
postgres 1503 0.0 0.0 215920 7248 ? Ss 09:43 0:07 postgres: nagiosxi nagiosxi ::1(53721) idle
postgres 1504 0.0 0.0 215976 7112 ? Ss 09:43 0:07 postgres: nagiosxi nagiosxi ::1(53722) idle
root 1562 0.0 0.0 4064 568 tty1 Ss+ 09:43 0:00 /sbin/mingetty /dev/tty1
root 1564 0.0 0.0 4064 568 tty2 Ss+ 09:43 0:00 /sbin/mingetty /dev/tty2
root 1566 0.0 0.0 10904 988 ? S< 09:43 0:00 /sbin/udevd -d
root 1567 0.0 0.0 4064 572 tty3 Ss+ 09:43 0:00 /sbin/mingetty /dev/tty3
root 1569 0.0 0.0 4064 568 tty4 Ss+ 09:43 0:00 /sbin/mingetty /dev/tty4
root 1571 0.0 0.0 4064 568 tty5 Ss+ 09:43 0:00 /sbin/mingetty /dev/tty5
root 1573 0.0 0.0 4064 568 tty6 Ss+ 09:43 0:00 /sbin/mingetty /dev/tty6
apache 1574 2.4 0.4 461544 36200 ? S 09:43 5:17 /usr/sbin/httpd
postgres 1575 0.0 0.0 215968 6892 ? Ss 09:43 0:07 postgres: nagiosxi nagiosxi ::1(53726) idle
postgres 1578 0.0 0.0 216016 6960 ? Ss 09:43 0:07 postgres: nagiosxi nagiosxi ::1(53727) idle
postgres 1579 0.0 0.0 216016 6892 ? Ss 09:43 0:07 postgres: nagiosxi nagiosxi ::1(53728) idle
postgres 1581 0.0 0.0 216016 7452 ? Ss 09:43 0:07 postgres: nagiosxi nagiosxi ::1(53729) idle
postgres 1595 0.0 0.0 215968 6856 ? Ss 09:43 0:07 postgres: nagiosxi nagiosxi ::1(53731) idle
apache 1610 2.4 0.4 464364 36936 ? S 09:43 5:15 /usr/sbin/httpd
apache 1611 2.4 0.4 461656 36328 ? S 09:43 5:20 /usr/sbin/httpd
postgres 1612 0.0 0.0 216060 7652 ? Ss 09:43 0:07 postgres: nagiosxi nagiosxi ::1(53736) idle
postgres 1615 0.0 0.0 215972 7124 ? Ss 09:43 0:07 postgres: nagiosxi nagiosxi ::1(53737) idle
apache 4953 2.4 0.4 461588 36196 ? S 09:45 5:16 /usr/sbin/httpd
postgres 4960 0.0 0.0 215452 6820 ? Ss 09:45 0:07 postgres: nagiosxi nagiosxi ::1(55496) idle
postfix 7745 0.0 0.0 79152 3332 ? S 13:03 0:00 pickup -l -t fifo -u
apache 17212 2.3 0.4 460936 35564 ? S 09:55 4:53 /usr/sbin/httpd
postgres 17240 0.0 0.0 215972 6964 ? Ss 09:55 0:07 postgres: nagiosxi nagiosxi ::1(35477) idle
apache 20094 2.3 0.4 461192 35520 ? S 09:58 4:49 /usr/sbin/httpd
postgres 20120 0.0 0.0 215968 6852 ? Ss 09:58 0:07 postgres: nagiosxi nagiosxi ::1(37343) idle
apache 22537 2.3 0.4 462056 36668 ? S 10:00 4:46 /usr/sbin/httpd
postgres 22574 0.0 0.0 216008 7392 ? Ss 10:00 0:07 postgres: nagiosxi nagiosxi ::1(38985) idle
root 26991 0.0 0.0 140100 1728 ? S 13:20 0:00 CROND
root 26992 0.0 0.0 140100 1728 ? S 13:20 0:00 CROND
root 26993 0.0 0.0 140100 1728 ? S 13:20 0:00 CROND
root 26994 0.0 0.0 140100 1728 ? S 13:20 0:00 CROND
root 26995 0.0 0.0 140100 1728 ? S 13:20 0:00 CROND
nagios 26999 0.0 0.0 9196 1188 ? Ss 13:20 0:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1
nagios 27000 0.0 0.0 9196 1188 ? Ss 13:20 0:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1
nagios 27006 0.0 0.0 9196 1188 ? Ss 13:20 0:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1
nagios 27007 0.0 0.0 9196 1188 ? Ss 13:20 0:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1
nagios 27008 0.0 0.0 9196 1184 ? Ss 13:20 0:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1
nagios 27009 0.4 0.3 232500 30280 ? S 13:20 0:00 /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php
nagios 27012 0.3 0.2 224984 22804 ? S 13:20 0:00 /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php
nagios 27014 0.3 0.2 224812 22296 ? S 13:20 0:00 /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php
nagios 27015 0.5 0.3 231976 25360 ? S 13:20 0:00 /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php
nagios 27017 0.3 0.2 224688 22452 ? S 13:20 0:00 /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php
postgres 27022 0.0 0.0 215456 6224 ? Ss 13:20 0:00 postgres: nagiosxi nagiosxi ::1(56539) idle
postgres 27030 0.0 0.0 215420 5896 ? Ss 13:20 0:00 postgres: nagiosxi nagiosxi ::1(56543) idle
postgres 27031 0.0 0.0 215420 5924 ? Ss 13:20 0:00 postgres: nagiosxi nagiosxi ::1(56544) idle
postgres 27038 0.0 0.0 215420 5928 ? Ss 13:20 0:00 postgres: nagiosxi nagiosxi ::1(56546) idle
postgres 27045 0.0 0.0 215456 6536 ? Ss 13:20 0:00 postgres: nagiosxi nagiosxi ::1(56548) idle
nagios 28024 0.0 0.0 41420 2884 ? S 13:20 0:00 /usr/local/nagios/libexec/check_nrpe -H kentest11g.snapon.com -u -p 5668 -t 70 -c check_zone_cpu -a -n kenamem01t -w 80 -
nagios 28033 0.0 0.0 41420 2884 ? S 13:20 0:00 /usr/local/nagios/libexec/check_nrpe -H kenamem01d.snapon.com -u -p 5668 -t 70 -c check_init_service -a svc:/network/inet
root 28034 0.0 0.0 110236 1172 pts/0 R+ 13:20 0:00 ps aux
root 28505 0.0 0.0 98160 4024 ? Ss 10:05 0:02 sshd: root@pts/0
root 28609 0.0 0.0 108452 1972 pts/0 Ss 10:05 0:00 -bash
apache 49930 2.4 0.4 462844 37496 ? S 10:26 4:17 /usr/sbin/httpd
postgres 49939 0.0 0.0 215972 6780 ? Ss 10:26 0:06 postgres: nagiosxi nagiosxi ::1(57028) idle
root 61820 0.0 0.0 108168 1564 pts/0 S 12:54 0:00 /bin/sh /usr/bin/mysqld_safe --datadir=/var/lib/mysql --socket=/var/lib/mysql/mysql.sock --pid-file=/var/run/mysqld/mysql
mysql 61922 5.1 0.5 2229452 47336 pts/0 Sl 12:54 1:22 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --log-error=/var/log/mysqld.log --pid-file=/var/
nagios 62245 0.0 0.0 50192 848 ? Ss 12:55 0:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios 62256 0.0 0.0 368888 1040 ? S 12:55 0:00 /usr/local/nagios/bin/npcd -d -f /usr/local/nagios/etc/pnp/npcd.cfg
nagios 62294 1.6 0.2 37348 16568 ? Ss 12:55 0:24 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 62296 0.1 0.0 10016 952 ? S 12:55 0:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 62297 0.0 0.0 10016 952 ? S 12:55 0:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 62298 0.0 0.0 10016 952 ? S 12:55 0:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 62299 0.0 0.0 10016 948 ? S 12:55 0:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 62300 0.0 0.0 10016 960 ? S 12:55 0:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 62301 0.0 0.0 10016 952 ? S 12:55 0:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 62302 0.1 0.0 50192 1592 ? S 12:55 0:01 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios 62303 1.0 0.1 61240 12756 ? S 12:55 0:16 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios 62326 0.0 0.1 36832 11220 ? S 12:55 0:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
150831 12:50:20 [Note] /usr/libexec/mysqld: Normal shutdown
150831 12:50:20 [Note] Event Scheduler: Purging the queue. 0 events
150831 12:50:22 InnoDB: Starting shutdown...
150831 12:50:24 InnoDB: Shutdown completed; log sequence number 0 44253
150831 12:50:24 [Note] /usr/libexec/mysqld: Shutdown complete
150831 12:50:24 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
150831 12:54:05 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
150831 12:54:05 InnoDB: Initializing buffer pool, size = 8.0M
150831 12:54:05 InnoDB: Completed initialization of buffer pool
150831 12:54:05 InnoDB: Started; log sequence number 0 44253
150831 12:54:05 [Note] Event Scheduler: Loaded 0 events
150831 12:54:05 [Note] /usr/libexec/mysqld: ready for connections.
