./backup_xi.sh
Backing up Core Config Manager (NagiosQL)...
tar: Removing leading `/' from member names
Backing up Nagios Core...
tar: /usr/local/nagios/var/ndo.sock: socket ignored
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var: file changed as we read it
tar: /usr/local/nagios/share/perfdata/KSKE4617701: file changed as we read it
tar: /usr/local/nagios/share/perfdata/K4505331: file changed as we read it
Backing up Nagios XI...
Backing up MRTG...
Backing up NRDP...
Backing up MySQL databases...
mysqldump: Got error: 144: Table './nagios/nagios_notifications' is marked as crashed and last (automatic?) repair failed when using LOCK TABLES
Error backing up MySQL database 'nagios' - check the password in this script!
I have been trying to take a backup all day and the backup never showed up in the GUI as a local backup. I decided to run the script from the command line to see if I was getting an error. Above is what I got when I ran from the command line.
It says to check the MySQL password in the script but when I look in the script there is no place that defines a MySQL password.
