Baseline monitoring
lafargeuser
Baseline monitoring
How can I achieve Baseline monitoring in Nagios XI
Re: Baseline monitoring
Can we please get a little more information on what you are looking to do?lafargeuser wrote:How can I achieve Baseline monitoring in Nagios XI
Former Nagios Employee.
me.
me.
lafargeuser
For example, if CPU utilization is high, the CPU isn’t automatically seen as the problem. Instead, memory and hard disk utilization should be considered. Is the system using an excessive amount of virtual memory? If that’s the case, CPU utilization might be a symptom of a memory problem rather than evidence of an insufficient CPU speed.
Then why don't you just monitor memory and cpu?
Nagios XI 5.8.1
https://outsideit.net
That functionality doesn't currently exist (although I agree it would be a great feature to have). You would have to write your own plugin to achieve what you're looking to do. We do offer custom development if that is something that you're interested in, you can contact [email protected] if you would like more information.
Thank you
Thank you
