Message not displaying properly
fabian.vanderhoeven
Post by fabian.vanderhoeven »
Another message which is not displayed properly. It is cut off at a bracket <
The raw message:
"_index": "logstash-2015.09.08",
"_type": "lumberjack",
"_id": "AU-sOkkG1Oc3ccf2E85k",
"_score": null,
"_source": {
"message": "2015-09-08T09:12:19.266Z;INM;PUB-managedServer-4;509081112195400004;1040;<BERICHT-OPC-PUB ID=\"2802\" OPC=\"NM\" VERSIE=\"1.0.0\" VERZENDMOMENT=\"2007-01-07T13:14:27Z\"><BERICHT-PUB-OPC ID=\"2421\"/><STATUS-OPC ONTVANGEN=\"9\" /></BERICHT-OPC-PUB> ",
"@version": "1",
"@timestamp": "2015-09-08T09:12:24.059Z",
"type": "lumberjack",
"file": "/var/log/weblogic/applications/AW5IPLUS/pub/log/PUB-LOG-PUB-managedServer-4-20150908-091214.224.csv",
"host": "adccaj.landelijk.ris",
"offset": "155284",
"sourcetype": "Appl-PUB",
"CorrelationID": "509081112195400004",
"ServerName": "PUB-managedServer-4",
"bericht_type": "INM",
"status_opc": "OPC ONTVANGEN=\"9\" ",
"trap": "1040",
"tags": [
"_grokparsefailure"
"sort": [
1441703544059,
1441703544059
The displayed message:
(see attachment)
jolson
Attack Rabbit
Re: Message not displaying properly
Post by jolson »
I imagine this is the same issue that cropped up in your other thread - I will speak with the developer more and let you know what we figure out. Thank you!
Twits Blog
