Hello experts. It's seems that when you write the configuration of a BPI, Nagios it's using the wrong character to update BPI Config file.
This error can be easily reproduced. Just create a new BPI or add more host/services to an already created:
After opening the BPI config file i've noticed that Nagios used ":" instead of ";"
Cannot create/update BPI After Upgrate to XI5.1
Re: Cannot create/update BPI After Upgrate to XI5.1
Hello, this issue has been fixed and will be in the new update of XI this week.
If you'd like to use the new component now, upload this in your Manage Components section in the admin panel.
It's working now! Thanks Jomann, you can go ahead and close this thread.
Great! Start a new thread if you need anything else.
