Default BBMap View
CFT6Server
Default BBMap View
Post by CFT6Server »
We have a lot of Hosts and services. Is there anyway to make it so that when we access the BBMap, it doesn't try to build a BBMap of everything until the user clicks the button or use the filter? Otherwise, it just takes forever to load the Default BBMap and hangs up the browser.
BanditBBS
Re: Default BBMap View
Post by BanditBBS »
Admin - Performance Settings - Auto-Run(cant remember which of the 2 checkboxes bbmap follows, but it does follow one of them)
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Thanks, BanditBBS!
@CFT6Server
Admin->Performance Settings->Auto-Running->Disable reports from automatically running on page load=selected->Update Settings
CFT6Server
My setting is already disabled.
But when you first click on BBMap, it is still trying to load all devices.
BanditBBS
Post by BanditBBS »
CFT6Server wrote:My setting is already disabled.
What version of XI and of the BBMap component? Adding BBMap came in a later version then when the checkboxes were first available.
CFT6Server
We are on XI 2014R2.6 right now, and started with the OVA. BBMap version is 1.1.
I have unchecked and rechecked the option and this doesn't seem to have any effect for bbmap and other maps as well as reports like Alert Heatmaps and Cloud
I am pretty sure, the option to respect the checkbox for not auto running reports was added to Version 1.1.3 of the BBMap component.
CFT6Server
To update the component, do I have to delete it first then re-upload? or can I just upload and it will automatically upgrade?
Anyways, I tested this on both our prod and test instances and BBMap is still running when I click on the link from home.
You can just upload it. No need for deleting it.
Were you running BBMap version is 1.1 on both boxes?
CFT6Server
Yes both are running 1.1.
