When I tried to delete a switch I had retired after the snapshot, I saw the behavior Louis described. I deleted the device from CCM, validated the config and restarted. However, while the switch was gone from CCM, flat files, and Nagios Core, XI still saw the switch and generated host down notifications. Likewise, a possibly unrelated NRPE problem on the host itself generated notifications from Core, but XI showed everything normal.
The wiki suggests trying this: https://support.nagios.com/wiki/index.p ... _Hosts.29. While the process lets me confirm the device has been removed from Core, it doesn't clean up XI in my case.
In an attempt to clear the switch from XI, I tweaked the deadpool settings to make sure it was included for cleanup. When deadpool.php runs, it skips the switch and logs this message:
PROCESSING HOSTS...
Processing host 'edge-2-sw.xxx.xxx.com' in stage 2
Error: Could not get ID for host 'edge-2-sw.xxx.xxx.com' - skipping
PROCESSED HOSTS:Moderator Edit: Link to original thread: https://support.nagios.com/forum/viewto ... 373#158001
I'm going to split this post in two so we can address the two of you separately. Please in the future if you are having a similar issue, create a new thread and link to the related one instead of posting directly in the related thread.
