I'm in need of having to rebuild my Nagios test server and I downloaded the latest source file from http://assets.nagios.com/downloads/nagi ... est.tar.gz. During the installation process I received this error:
Sorry, user root is not allowed to execute './reset_config_perms.sh' as root on lnsvr0615.
RESETTING CONFIG PERMS FAILED!\n
RESULT=1
After the error I attempted to run reset_config_perms.sh from the command line and then I got
/bin/chown: cannot access `/usr/local/nagiosxi/nom/checkpoints/nagiosxi': No such file or directory
I cd into /usr/local/nagiosxi/nom/checkpoints and all I see it
[root@lnsvr0615 ~]# cd /usr/local/nagiosxi/nom/checkpoints/
[root@lnsvr0615 checkpoints]# ll
total 4
drwxr-xr-x 3 nagios nagios 4096 Oct 27 17:42 nagioscore
I uploaded the install.log file.
--Berto
Issue with Installing Nagios XI latest source rpm
- Box293
- Too Basu
Re: Issue with Installing Nagios XI latest source rpm
Can you please upload the file:
/etc/sudoers
Also, any files in /etc/sudoers.d/
/etc/sudoers
I have uploaded the sudoers file. Also, there aren't any files in /etc/sudoers.d/
ll /etc/sudoers.d/
total 0
--Berto
ll /etc/sudoers.d/
total 0
--Berto
The sudoers file looks proper, please post the output of these commands:
Also, attach a sanitized copy of your xi-sys.cfg from your installer directory.
Thank you
grep nag /etc/group
grep apache /etc/groupThank you
Here is the requested info.
-bash-4.1$ grep nag /etc/group (LDAP group is used for nagios)
-bash-4.1$ grep apache /etc/group
apache
48:
--Berto
apache
--Berto
How was Redhat installed initially? Was it a minimal install? Was the server used for anything before? Any security settings in place?
How about SELinux, is that enabled? You can check with getenforce.
I did a fresh install of RHEL6.6 from kickstart using Satellite server. There are no security settings in place, and SELinux is disabled. The install was a minimum install (no apache, etc.).
I've installed Nagios XI prior before with no issues with a few changes that I need to do in the fullinstall script due to our corp proxy and using LDAP for nagios user and group.
[root@lnsvr0615 ~]# getenforce
Disabled
--Berto
Disabled
--Berto
Taking a look at the end of your install log I noticed -
Has this server been hardened to restrict root's privileges? Please add root ALL=(ALL) ALL to /etc/sudoers, this will grant root the permissions needed.
In our environment LDAP is used for sudo and hasn't been an issue in the past before when installing Nagios XI. I see that in /etc/sudoers that entry already exists on the server I'm having issues with the installation. If I try running the command manually as root I get this error:
[root@lnsvr0615 nagiosxi]# /usr/local/nagiosxi/scripts/reset_config_perms.sh
RESETTING PERMS
When doing an ll you can see that indeed the nagiosxi file/directory it's looking for doesn't exist:
[root@lnsvr0615 nagiosxi]# ll /usr/local/nagiosxi/nom/checkpoints/
drwxr-xr-x 3 nagios nagios 4096 Oct 31 14:26 nagioscore
So not sure if it's exactly that root can't run the file due to permissions or that really it doesn't see that file/directory and it shoots out that error.
--Berto
RESETTING PERMS
--Berto
If ldap is handling sudo, please post a sanitized copy of your ldap sudoers entries as that is likely what's causing the issue.
