Error with upgrading to 5.2.0
jimhoffmann
Post by jimhoffmann »
Attempting to upgrade our Nagios server from 2014R2.7 to 5.2.0. During the backup of MYSQL I get the following message:
Backing up MySQL databases...
mysqldump: Got error: 130: Incorrect file format 'nagios_statehistory' when using LOCK TABLES
Error backing up MySQL database 'nagios' - check the password in this script!
I have twice already ran the script to repair the database but that did not seem to resolve the issue.
Re: Error with upgrading to 5.2.0
Can you run the following command and post the output?
tail -n 100 /var/log/mysqld.log
Also, please verify the SQL password in a couple files. (it should be nagiosxi)
grep "mysqlpass=" /usr/local/nagiosxi/scripts/restore_xi.sh
grep "PASSWORD=" /root/scripts/automysqlbackup
jimhoffmann
Here is the output from the tail:
150919 15:59:06 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
150919 15:59:07 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
150919 15:59:08 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
150919 15:59:09 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
150919 15:59:10 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
150919 15:59:12 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
150919 15:59:14 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
150919 15:59:15 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
150919 15:59:16 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
150919 15:59:18 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
150919 15:59:19 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
150919 15:59:21 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
150919 15:59:22 [Note] /usr/libexec/mysqld: Normal shutdown
150919 15:59:22 [Note] Event Scheduler: Purging the queue. 0 events
150919 15:59:24  InnoDB: Starting shutdown...
150919 15:59:28  InnoDB: Shutdown completed; log sequence number 0 44253
150919 15:59:28 [Note] /usr/libexec/mysqld: Shutdown complete
150919 15:59:28 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
150919 15:59:32 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
150919 15:59:32  InnoDB: Initializing buffer pool, size = 8.0M
150919 15:59:32  InnoDB: Completed initialization of buffer pool
150919 15:59:32  InnoDB: Started; log sequence number 0 44253
150919 15:59:32 [Note] Event Scheduler: Loaded 0 events
150919 15:59:32 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.1.73'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  Source distribution
151030 12:03:08 [Note] /usr/libexec/mysqld: Normal shutdown
151030 12:03:08 [Note] Event Scheduler: Purging the queue. 0 events
151030 12:03:08  InnoDB: Starting shutdown...
151030 12:03:13  InnoDB: Shutdown completed; log sequence number 0 44253
151030 12:03:13 [Note] /usr/libexec/mysqld: Shutdown complete
151030 12:03:14 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
151030 12:03:50 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
151030 12:03:50  InnoDB: Initializing buffer pool, size = 8.0M
151030 12:03:50  InnoDB: Completed initialization of buffer pool
151030 12:03:50  InnoDB: Started; log sequence number 0 44253
151030 12:03:50 [Note] Event Scheduler: Loaded 0 events
151030 12:03:50 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.1.73'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  Source dis[root@nagios01 ~]# tail -n 100 /var/log/mysqld.log
151030 15:23:41 [Note] /usr/libexec/mysqld: Normal shutdown
151030 15:23:41 [Note] Event Scheduler: Purging the queue. 0 events
151030 15:23:41  InnoDB: Starting shutdown...
151030 15:23:42  InnoDB: Shutdown completed; log sequence number 0 44253
151030 15:23:42 [Note] /usr/libexec/mysqld: Shutdown complete
151030 15:23:42 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
151030 15:24:17 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
151030 15:24:17  InnoDB: Initializing buffer pool, size = 8.0M
151030 15:24:17  InnoDB: Completed initialization of buffer pool
151030 15:24:18  InnoDB: Started; log sequence number 0 44253
151030 15:24:18 [Note] Event Scheduler: Loaded 0 events
151030 15:24:18 [Note] /usr/libexec/mysqld: ready for connections.
[root@nagios01 ~]#
Reason: Please wrap long outputs in [code][/code] tags.
Can you please verify the password as well by running the following two commands?
jimhoffmann
I verified that when I ran the commands both are nagiosxi.
Ah - didn't know if you did or not. Thanks for verifying. Try running the following commands to see if this fixes the table in question. Let me know the output.
service mysqld stop
cd /var/lib/mysql/nagios
myisamchk -r -f nagios_statehistory
myisamchk -r -f nagios_hoststatus
service mysqld start
rm -f /usr/local/nagiosxi/var/dbmaint.lock
/usr/local/nagiosxi/cron/dbmaint.php
jimhoffmann
Here are the outputs from the commands you gave:
[root@nagios01 ~]# service mysqld stop
Stopping mysqld: [ OK ]
[root@nagios01 ~]# cd /var/lib/mysql/nagios
[root@nagios01 nagios]# myisamchk -r -f nagios_statehistory
myisamchk: error: 'nagios_statehistory' is not a MyISAM-table
[root@nagios01 nagios]# myisamchk -r -f nagios_hoststatus
- recovering (with sort) MyISAM-table 'nagios_hoststatus'
Data records: 160
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- Fixing index 6
- Fixing index 7
- Fixing index 8
- Fixing index 9
- Fixing index 10
- Fixing index 11
- Fixing index 12
- Fixing index 13
- Fixing index 14
- Fixing index 15
- Fixing index 16
- Fixing index 17
- Fixing index 18
- Fixing index 19
[root@nagios01 nagios]# rm -f /usr/local/nagiosxi/var/dbmaint.lock
[root@nagios01 nagios]# /usr/local/nagiosxi/cron/dbmaint.php
/bin/env: php -q: No such file or directory
sorry, please run
php /usr/local/nagiosxi/cron/dbmaint.php
jimhoffmann
I went through the list of commands again and here is what the Output shows:
[root@nagios01 ~]# service mysqld start
Starting mysqld:                                           [  OK  ]
Data records: 160
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- Fixing index 6
- Fixing index 7
- Fixing index 8
- Fixing index 9
- Fixing index 10
- Fixing index 11
- Fixing index 12
- Fixing index 13
- Fixing index 14
- Fixing index 15
- Fixing index 16
- Fixing index 17
- Fixing index 18
- Fixing index 19
[root@nagios01 nagios]# service mysqld start
[root@nagios01 nagios]# php /usr/local/nagiosxi/cron/dbmaint.php
CREATING: /usr/local/nagiosxi/var/dbmaint.lock
CLEANING ndoutils TABLE 'commenthistory'...
SQL: DELETE FROM nagios_commenthistory WHERE entry_time < FROM_UNIXTIME(1415111410)
CLEANING ndoutils TABLE 'processevents'...
SQL: DELETE FROM nagios_processevents WHERE event_time < FROM_UNIXTIME(1415111410)
CLEANING ndoutils TABLE 'externalcommands'...
SQL: DELETE FROM nagios_externalcommands WHERE entry_time < FROM_UNIXTIME(1446042610)
CLEANING ndoutils TABLE 'logentries'...
SQL: DELETE FROM nagios_logentries WHERE logentry_time < FROM_UNIXTIME(1438871410)
CLEANING ndoutils TABLE 'notifications'...
SQL: DELETE FROM nagios_notifications WHERE start_time < FROM_UNIXTIME(1438871410)
CLEANING ndoutils TABLE 'contactnotifications'...
SQL: DELETE FROM nagios_contactnotifications WHERE start_time < FROM_UNIXTIME(1438871410)
CLEANING ndoutils TABLE 'contactnotificationmethods'...
SQL: DELETE FROM nagios_contactnotificationmethods WHERE start_time < FROM_UNIXTIME(1438871410)
CLEANING ndoutils TABLE 'statehistory'...
SQL: DELETE FROM nagios_statehistory WHERE state_time < FROM_UNIXTIME(1383575410)
    SQL:     SQL Error [ndoutils] :</b> Incorrect file format 'nagios_statehistory'CLEANING ndoutils TABLE 'timedevents'...
SQL: DELETE FROM nagios_timedevents WHERE event_time < FROM_UNIXTIME(1446647110)
CLEANING ndoutils TABLE 'systemcommands'...
SQL: DELETE FROM nagios_systemcommands WHERE start_time < FROM_UNIXTIME(1446647110)
    SQL:     SQL Error [ndoutils] :</b> Incorrect file format 'nagios_systemcommands'CLEANING ndoutils TABLE 'servicechecks'...
SQL: DELETE FROM nagios_servicechecks WHERE start_time < FROM_UNIXTIME(1446647110)
CLEANING ndoutils TABLE 'hostchecks'...
SQL: DELETE FROM nagios_hostchecks WHERE start_time < FROM_UNIXTIME(1446647110)
CLEANING ndoutils TABLE 'eventhandlers'...
SQL: DELETE FROM nagios_eventhandlers WHERE start_time < FROM_UNIXTIME(1446647110)
TIME TO OPTIMIZE
LASTOPT:  1446643802
INTERVAL: 60
NOW:      1446647410
OPTTIME:  1446647402
OPTIMIZING NDOUTILS TABLE: nagios_acknowledgements
SQL: OPTIMIZE TABLE nagios_acknowledgements
OPTIMIZING NDOUTILS TABLE: nagios_commands
SQL: OPTIMIZE TABLE nagios_commands
OPTIMIZING NDOUTILS TABLE: nagios_commenthistory
SQL: OPTIMIZE TABLE nagios_commenthistory
OPTIMIZING NDOUTILS TABLE: nagios_comments
SQL: OPTIMIZE TABLE nagios_comments
OPTIMIZING NDOUTILS TABLE: nagios_configfiles
SQL: OPTIMIZE TABLE nagios_configfiles
OPTIMIZING NDOUTILS TABLE: nagios_configfilevariables
SQL: OPTIMIZE TABLE nagios_configfilevariables
OPTIMIZING NDOUTILS TABLE: nagios_conninfo
SQL: OPTIMIZE TABLE nagios_conninfo
OPTIMIZING NDOUTILS TABLE: nagios_contact_addresses
SQL: OPTIMIZE TABLE nagios_contact_addresses
OPTIMIZING NDOUTILS TABLE: nagios_contact_notificationcommands
SQL: OPTIMIZE TABLE nagios_contact_notificationcommands
OPTIMIZING NDOUTILS TABLE: nagios_contactgroup_members
SQL: OPTIMIZE TABLE nagios_contactgroup_members
OPTIMIZING NDOUTILS TABLE: nagios_contactgroups
SQL: OPTIMIZE TABLE nagios_contactgroups
OPTIMIZING NDOUTILS TABLE: nagios_contactnotificationmethods
SQL: OPTIMIZE TABLE nagios_contactnotificationmethods
OPTIMIZING NDOUTILS TABLE: nagios_contactnotifications
SQL: OPTIMIZE TABLE nagios_contactnotifications
OPTIMIZING NDOUTILS TABLE: nagios_contacts
SQL: OPTIMIZE TABLE nagios_contacts
OPTIMIZING NDOUTILS TABLE: nagios_contactstatus
SQL: OPTIMIZE TABLE nagios_contactstatus
OPTIMIZING NDOUTILS TABLE: nagios_customvariables
SQL: OPTIMIZE TABLE nagios_customvariables
OPTIMIZING NDOUTILS TABLE: nagios_customvariablestatus
SQL: OPTIMIZE TABLE nagios_customvariablestatus
OPTIMIZING NDOUTILS TABLE: nagios_dbversion
SQL: OPTIMIZE TABLE nagios_dbversion
OPTIMIZING NDOUTILS TABLE: nagios_downtimehistory
SQL: OPTIMIZE TABLE nagios_downtimehistory
OPTIMIZING NDOUTILS TABLE: nagios_eventhandlers
SQL: OPTIMIZE TABLE nagios_eventhandlers
OPTIMIZING NDOUTILS TABLE: nagios_externalcommands
SQL: OPTIMIZE TABLE nagios_externalcommands
OPTIMIZING NDOUTILS TABLE: nagios_flappinghistory
SQL: OPTIMIZE TABLE nagios_flappinghistory
OPTIMIZING NDOUTILS TABLE: nagios_host_contactgroups
SQL: OPTIMIZE TABLE nagios_host_contactgroups
OPTIMIZING NDOUTILS TABLE: nagios_host_contacts
SQL: OPTIMIZE TABLE nagios_host_contacts
OPTIMIZING NDOUTILS TABLE: nagios_host_parenthosts
SQL: OPTIMIZE TABLE nagios_host_parenthosts
OPTIMIZING NDOUTILS TABLE: nagios_hostchecks
SQL: OPTIMIZE TABLE nagios_hostchecks
OPTIMIZING NDOUTILS TABLE: nagios_hostdependencies
SQL: OPTIMIZE TABLE nagios_hostdependencies
OPTIMIZING NDOUTILS TABLE: nagios_hostescalation_contactgroups
SQL: OPTIMIZE TABLE nagios_hostescalation_contactgroups
OPTIMIZING NDOUTILS TABLE: nagios_hostescalation_contacts
SQL: OPTIMIZE TABLE nagios_hostescalation_contacts
OPTIMIZING NDOUTILS TABLE: nagios_hostescalations
SQL: OPTIMIZE TABLE nagios_hostescalations
OPTIMIZING NDOUTILS TABLE: nagios_hostgroup_members
SQL: OPTIMIZE TABLE nagios_hostgroup_members
OPTIMIZING NDOUTILS TABLE: nagios_hostgroups
SQL: OPTIMIZE TABLE nagios_hostgroups
OPTIMIZING NDOUTILS TABLE: nagios_hosts
SQL: OPTIMIZE TABLE nagios_hosts
OPTIMIZING NDOUTILS TABLE: nagios_hoststatus
SQL: OPTIMIZE TABLE nagios_hoststatus
OPTIMIZING NDOUTILS TABLE: nagios_instances
SQL: OPTIMIZE TABLE nagios_instances
OPTIMIZING NDOUTILS TABLE: nagios_logentries
SQL: OPTIMIZE TABLE nagios_logentries
OPTIMIZING NDOUTILS TABLE: nagios_notifications
SQL: OPTIMIZE TABLE nagios_notifications
OPTIMIZING NDOUTILS TABLE: nagios_objects
SQL: OPTIMIZE TABLE nagios_objects
OPTIMIZING NDOUTILS TABLE: nagios_processevents
SQL: OPTIMIZE TABLE nagios_processevents
OPTIMIZING NDOUTILS TABLE: nagios_programstatus
SQL: OPTIMIZE TABLE nagios_programstatus
OPTIMIZING NDOUTILS TABLE: nagios_runtimevariables
SQL: OPTIMIZE TABLE nagios_runtimevariables
OPTIMIZING NDOUTILS TABLE: nagios_scheduleddowntime
SQL: OPTIMIZE TABLE nagios_scheduleddowntime
OPTIMIZING NDOUTILS TABLE: nagios_service_contactgroups
SQL: OPTIMIZE TABLE nagios_service_contactgroups
OPTIMIZING NDOUTILS TABLE: nagios_service_contacts
SQL: OPTIMIZE TABLE nagios_service_contacts
OPTIMIZING NDOUTILS TABLE: nagios_servicechecks
SQL: OPTIMIZE TABLE nagios_servicechecks
OPTIMIZING NDOUTILS TABLE: nagios_servicedependencies
SQL: OPTIMIZE TABLE nagios_servicedependencies
OPTIMIZING NDOUTILS TABLE: nagios_serviceescalation_contactgroups
SQL: OPTIMIZE TABLE nagios_serviceescalation_contactgroups
OPTIMIZING NDOUTILS TABLE: nagios_serviceescalation_contacts
SQL: OPTIMIZE TABLE nagios_serviceescalation_contacts
OPTIMIZING NDOUTILS TABLE: nagios_serviceescalations
SQL: OPTIMIZE TABLE nagios_serviceescalations
OPTIMIZING NDOUTILS TABLE: nagios_servicegroup_members
SQL: OPTIMIZE TABLE nagios_servicegroup_members
OPTIMIZING NDOUTILS TABLE: nagios_servicegroups
SQL: OPTIMIZE TABLE nagios_servicegroups
OPTIMIZING NDOUTILS TABLE: nagios_services
SQL: OPTIMIZE TABLE nagios_services
OPTIMIZING NDOUTILS TABLE: nagios_servicestatus
SQL: OPTIMIZE TABLE nagios_servicestatus
OPTIMIZING NDOUTILS TABLE: nagios_statehistory
SQL: OPTIMIZE TABLE nagios_statehistory
OPTIMIZING NDOUTILS TABLE: nagios_systemcommands
SQL: OPTIMIZE TABLE nagios_systemcommands
OPTIMIZING NDOUTILS TABLE: nagios_timedeventqueue
SQL: OPTIMIZE TABLE nagios_timedeventqueue
OPTIMIZING NDOUTILS TABLE: nagios_timedevents
SQL: OPTIMIZE TABLE nagios_timedevents
OPTIMIZING NDOUTILS TABLE: nagios_timeperiod_timeranges
SQL: OPTIMIZE TABLE nagios_timeperiod_timeranges
OPTIMIZING NDOUTILS TABLE: nagios_timeperiods
SQL: OPTIMIZE TABLE nagios_timeperiods
CLEANING nagiosxi TABLE 'commands'...
SQL: DELETE FROM xi_commands WHERE processing_time < 1446618610::abstime::timestamp without time zone
CLEANING nagiosxi TABLE 'events'...
SQL: DELETE FROM xi_events WHERE processing_time < 1446618610::abstime::timestamp without time zone
SQL1: SELECT xi_meta.meta_id FROM xi_meta LEFT JOIN xi_events ON xi_meta.metaobj_id=xi_events.event_id WHERE metatype_id='1' AND event_id IS NULL
SQL2: DELETE FROM xi_meta WHERE meta_id IN (SELECT xi_meta.meta_id FROM xi_meta LEFT JOIN xi_events ON xi_meta.metaobj_id=xi_events.event_id WHERE metatype_id='1' AND event_id IS NULL)
CLEANING nagiosxi TABLE 'auditlog'...
SQL: DELETE FROM xi_auditlog WHERE log_time < 1444055410::abstime::timestamp without time zone
OPTIMIZING NAGIOSXI TABLE: xi_auditlog
SQL: VACUUM ANALYZE xi_auditlog;
OPTIMIZING NAGIOSXI TABLE: xi_commands
SQL: VACUUM ANALYZE xi_commands;
OPTIMIZING NAGIOSXI TABLE: xi_events
SQL: VACUUM ANALYZE xi_events;
OPTIMIZING NAGIOSXI TABLE: xi_notifications
SQL: VACUUM ANALYZE xi_notifications;
    SQL:     SQL Error [nagiosxi] :</b> ERROR:  relation "xi_notifications" does not existOPTIMIZING NAGIOSXI TABLE: xi_meta
SQL: VACUUM ANALYZE xi_meta;
OPTIMIZING NAGIOSXI TABLE: xi_options
SQL: VACUUM ANALYZE xi_options;
OPTIMIZING NAGIOSXI TABLE: xi_sysstat
SQL: VACUUM ANALYZE xi_sysstat;
OPTIMIZING NAGIOSXI TABLE: xi_usermeta
SQL: VACUUM ANALYZE xi_usermeta;
OPTIMIZING NAGIOSXI TABLE: xi_users
SQL: VACUUM ANALYZE xi_users;
CLEANING nagiosql TABLE 'logbook'...
SQL: DELETE FROM tbl_logbook WHERE time < FROM_UNIXTIME(1446618610)
OPTIMIZING NAGIOSQL TABLE: tbl_contact
SQL: OPTIMIZE TABLE tbl_contact
OPTIMIZING NAGIOSQL TABLE: tbl_host
SQL: OPTIMIZE TABLE tbl_host
OPTIMIZING NAGIOSQL TABLE: tbl_hostgroup
SQL: OPTIMIZE TABLE tbl_hostgroup
OPTIMIZING NAGIOSQL TABLE: tbl_lnkHostgroupToHost
SQL: OPTIMIZE TABLE tbl_lnkHostgroupToHost
OPTIMIZING NAGIOSQL TABLE: tbl_lnkHostToHost
SQL: OPTIMIZE TABLE tbl_lnkHostToHost
OPTIMIZING NAGIOSQL TABLE: tbl_lnkHostToHostgroup
SQL: OPTIMIZE TABLE tbl_lnkHostToHostgroup
OPTIMIZING NAGIOSQL TABLE: tbl_lnkHostdependencyToHost_DH
SQL: OPTIMIZE TABLE tbl_lnkHostdependencyToHost_DH
OPTIMIZING NAGIOSQL TABLE: tbl_lnkHostdependencyToHost_H
SQL: OPTIMIZE TABLE tbl_lnkHostdependencyToHost_H
OPTIMIZING NAGIOSQL TABLE: tbl_lnkServiceToHost
SQL: OPTIMIZE TABLE tbl_lnkServiceToHost
OPTIMIZING NAGIOSQL TABLE: tbl_lnkServicedependencyToService_DS
SQL: OPTIMIZE TABLE tbl_lnkServicedependencyToService_DS
OPTIMIZING NAGIOSQL TABLE: tbl_lnkServicedependencyToService_S
SQL: OPTIMIZE TABLE tbl_lnkServicedependencyToService_S
OPTIMIZING NAGIOSQL TABLE: tbl_lnkServiceToHostgroup
SQL: OPTIMIZE TABLE tbl_lnkServiceToHostgroup
OPTIMIZING NAGIOSQL TABLE: tbl_lnkServiceToServicegroup
SQL: OPTIMIZE TABLE tbl_lnkServiceToServicegroup
OPTIMIZING NAGIOSQL TABLE: tbl_logbook
SQL: OPTIMIZE TABLE tbl_logbook
OPTIMIZING NAGIOSQL TABLE: tbl_service
SQL: OPTIMIZE TABLE tbl_service
OPTIMIZING NAGIOSQL TABLE: tbl_servicegroup
SQL: OPTIMIZE TABLE tbl_servicegroup
OPTIMIZING NAGIOSQL TABLE: tbl_timeperiod
SQL: OPTIMIZE TABLE tbl_timeperiod
OPTIMIZING NAGIOSQL TABLE: tbl_timedefinition
SQL: OPTIMIZE TABLE tbl_timedefinition
OPTIMIZING NAGIOSQL TABLE: tbl_user
SQL: OPTIMIZE TABLE tbl_user
Repair Complete: Removing Lock File
I ran the Upgrade again and still get the same error:
---- Starting Nagios XI Backup ----
No entry for terminal type "unknown";
using dumb terminal settings.
Backing up Core Config Manager (NagiosQL)...
tar: Removing leading `/' from member names
Backing up Nagios Core...
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var/ndo.sock: socket ignored
tar: /usr/local/nagios/var: file changed as we read it
tar: /usr/local/nagios/share/perfdata/ucsattendcon01.sfmic.local: file changed as we read it
Backing up Nagios XI...
Backing up MRTG...
Backing up NRDP...
Reason: Please use [code][/code] tags around long output
jimhoffmann
I followed the Repairing the Database documentation and found the following output:
myisamchk: error: 'nagios_statehistory.MYI' is not a MyISAM-table
myisamchk: error: 'nagios_systemcommands.MYI' is not a MyISAM-table
I see the nagios_statehistory come up when it is attempting to backup the database and fails.
