Check_NRPE returns version, but cannot remote execute
RyanW
Post by RyanW »
I have seen similar questions asked, but I have not seen one which fits this use case specifically.
Basically executing the base check-nrpe to the remote host will return the remote nrpe version:
[root@nagios agile-u2]# /usr/lib/nagios/plugins/check_nrpe -H agile-db-u2
NRPE v2.15
When you add a command to the end of the check command it returns the following:
[root@nagios agile-u2]# /usr/lib/nagios/plugins/check_nrpe -H agile-db-u2 -c check_root
NRPE: Unable to read output
The remote command defined in /etc/nagios/nrpe.cfg:
command[check_root]=/usr/lib/nagios/plugins/check_disk -w 20% -c 10% /dev/mapper/vg_agiledbd1-lv_root
Disk path confirmed:
Plugin path confirmed:
[root@agile-db-u2 plugins]# pwd
[root@agile-db-u2 plugins]# ls
check_disk
Executing the check_disk command locally works as well:
[root@agile-db-u2 plugins]# /usr/lib/nagios/plugins/check_disk -v -v
DISK OK - free space: / 0 MB (0% inode=97%); /dev/shm 7974 MB (99% inode=99%); /boot 333 MB (73% inode=99%); /u02 23333 MB (24% inode=99%); /agileNAS 138148 MB (38% inode=99%);| /=65256MB;;;0;68165 /dev/shm=0MB;;;0;7975 /boot=117MB;;;0;476 /u02=72208MB;;;0;100661 /agileNAS=220251MB;;;0;358400
I have used this same nrpe.cfg file on a couple of other servers and it has worked without issue. This seems to be currently effecting 4 out of 12 in the deployment. All of the systems are running identical version of SSL, NRPE, OS..etc.
Has anyone else experienced this issue?
hsmith
Agent Smith
Re: Check_NRPE returns version, but cannot remote execute
Post by hsmith »
How did you install NRPE? Is this running as a standalone daemon, or using xinetd?
Former Nagios Employee.
me.
RyanW
Post by RyanW »
I installed it from the EPEL repos, it is currently running under init.d.
**For startup reasons it's running under init.d, but to actually start the command for testing and such, I'm using "service nrpe restart/start/stop"
I have tried running it standalone: nrpe -n -c /etc/nagios/nrpe.cfg -d and received a socket timeout, which I believe was due to the -n flag.
Actually, I just ran standalone without the -n flag:
[root@agile-db-u2 init.d]# nrpe -c /etc/nagios/nrpe.cfg -d
Tested from the server and received:
DISK CRITICAL - free space: / 0 MB (0% inode=97%);| /=65256MB;54532;61348;0;68165
What would be the difference between running under init.d and standalone?
-R
jdalrymple
Skynet Drone
Post by jdalrymple »
RyanW wrote:[root@agile-db-u2 init.d]# nrpe -c /etc/nagios/nrpe.cfg -d
There is your difference most likely. Try launching as user nagios and see if you get the same results.
RyanW
Post by RyanW »
jdalrymple you are correct:
[root@agile-db-u2 xinetd.d]# ps -ef | grep -i nrpe
nrpe 19770 1 0 13:14 ? 00:00:00 /usr/sbin/nrpe -c /etc/nagios/nrpe.cfg -d
When it is run as root I do receive output, as the user specified in the nrpe.cfg (nrpe) I do NOT receive output.
Does it help if you put the following line in sudoers on the remote box?
nagios   ALL = NOPASSWD:/usr/lib/nagios/plugins/check_disk *
RyanW
Post by RyanW »
lmiltchev wrote:Does it help if you put the following line in sudoers on the remote box?
Just gave it a try and restarted services, but it was unsuccessful.
I'm taking a look at the other systems now to look for discrepancies in users/groups, but so far, the process gets spawned as the nrpe user on other systems and it is working! :?
Working client:
[root@agile-proxy-u2 ~]# ps -ef | grep -i nrpe
nrpe 14943 1 0 Nov04 ? 00:00:00 /usr/sbin/nrpe -c /etc/nagios/nrpe.cfg -d
Broken client:
[root@agile-db-u2 nagios]# ps -ef | grep -i nrpe
nrpe 20530 1 0 14:27 ? 00:00:00 /usr/sbin/nrpe -c /etc/nagios/nrpe.cfg -d
These are using the same nrpe.cfg file with tweaks to the custom check dev path.
-R
Post by Box293 »
RyanW wrote:jdalrymple you are correct:
IF your user is nrpe then the sudoers line needs to start with nrpe (I'm pretty sure):
nrpe   ALL = NOPASSWD:/usr/lib/nagios/plugins/check_disk *
RyanW
Post by RyanW »
Box293 wrote:IF your user is nrpe then the sudoers line needs to start with nrpe (I'm pretty sure):
I noticed the user is NRPE and added that line to the sudoers file as well, still returned the same results.
RyanW
Post by RyanW »
Thanks for all of the input, from everything I've gathered it's a user/group issue.
As to why it is working on the other machines, I have not been able to figure that one out yet.
If I get a definitive solution I will report back.
Thanks guys!
