Just wanted to see if anyone was able to fine tune the mibs for the following. Basically I wanted to find out the following for this UPS. Any help would be greatly appreciated. Thank you.
UPS Capacity
UPS Current
UPS Freq In
UPS Freq Out
UPS Last Battery Replacement
UPS Load
UPS Manufacture Date
UPS RunTime
UPS Status
UPS Temp
UPS Test Date
UPS Test Result
UPS Volts In
UPS Volts Out
Here is some what of a break down of what I was able to put together.
.1.3.6.1.2.1.2.2.1.1.1 == interfaces.ifTable.ifEntry.ifIndex.1
1 1 1 1 1 1 1 1 1 0 1 (00000) == (ff.a0)
| | | |-- the index
| | |---- the column
| |------ ifEntry
|-------- ifTable
iso.3.6.1.4.1.318.2.1.6.1.0 ( shows today's date )
iso.3.6.1.4.1.318.2.1.6.2.0 ( shows today's time )
.1.3.6.1.4.1.318.1.1.25.1.2.1.6.1.1 ( Temperature )
.1.3.6.1.4.1.318.1.1.25.1.2.1.7.1.1 ( Humidity )
Here some stuff that I was able to dig out but not sure exactly what it is (I understand the what the results say but not to what query):
SNMP OK - 1 | iso.3.6.1.4.1.318.1.1.25.1.2.1.1.1.1=1
SNMP OK - 1 | iso.3.6.1.4.1.318.1.1.25.1.2.1.2.1.1=1
SNMP OK - = "" |
SNMP OK - = "" |
SNMP OK - -1 | iso.3.6.1.4.1.318.1.1.25.1.2.1.5.1.1=-1
SNMP OK - -1 | iso.3.6.1.4.1.318.1.1.25.1.2.1.6.1.1=-1
SNMP OK - -1 | iso.3.6.1.4.1.318.1.1.25.1.2.1.7.1.1=-1
SNMP OK - 0 | iso.3.6.1.4.1.318.1.1.25.1.2.1.8.1.1=0
SNMP OK - 4 | iso.3.6.1.4.1.318.1.1.25.1.2.1.9.1.1=4
SNMP OK - 1 | iso.3.6.1.4.1.318.1.1.25.1.2.1.10.1.1=1
Here is an snmpwalk output that I was able to "truncate".
iso.3.6.1.2.1.1.1.0 = STRING: "APC Web/SNMP Management Card (MB:v4.0.1 PF:v6.0.6 PN:apc_hw05_aos_606.bin AF1:v6.0.6 AN1:apc_hw05_sy_606.bin MN:AP9631 HR:05 SN: ZA1035005223 MD:08/25/2010) (Embedded PowerNet SNMP Agent SW v2.2 compatible)"
iso.3.6.1.2.1.1.2.0 = OID: iso.3.6.1.4.1.318
iso.3.6.1.2.1.1.3.0 = Timeticks: (395652520) 45 days, 19:02:05.20
iso.3.6.1.2.1.1.4.0 = STRING: "admins"
iso.3.6.1.2.1.1.5.0 = STRING: "building-info"
iso.3.6.1.2.1.1.6.0 = STRING: "room-location"
iso.3.6.1.2.1.1.7.0 = INTEGER: 72
iso.3.6.1.2.1.1.8.0 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.2.1 = OID: iso.3.6.1.6.3.1
iso.3.6.1.2.1.1.9.1.2.2 = OID: iso.3.6.1.6.3.10.3.1.1
iso.3.6.1.2.1.1.9.1.2.3 = OID: iso.3.6.1.6.3.11.3.1.1
iso.3.6.1.2.1.1.9.1.2.4 = OID: iso.3.6.1.6.3.15.2.1.1
iso.3.6.1.2.1.1.9.1.2.5 = OID: iso.3.6.1.6.3.16.2.1.1
iso.3.6.1.2.1.1.9.1.3.1 = STRING: "The MIB Module from SNMPv2 entities"
iso.3.6.1.2.1.1.9.1.3.2 = STRING: "SNMP Management Architecture MIB"
iso.3.6.1.2.1.1.9.1.3.3 = STRING: "Message Processing and Dispatching MIB"
iso.3.6.1.2.1.1.9.1.3.4 = STRING: "USM User MIB"
iso.3.6.1.2.1.1.9.1.3.5 = STRING: "VACM MIB"
iso.3.6.1.2.1.1.9.1.4.1 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.2 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.3 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.4 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.1.9.1.4.5 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.2.2.1.22.1 = OID: ccitt.0
iso.3.6.1.2.1.2.2.1.22.2 = OID: ccitt.0
iso.3.6.1.2.1.3.1.1.3.2.1.x.x.x.x = IpAddress: x.x.x.x
iso.3.6.1.2.1.4.1.0 = INTEGER: 2
iso.3.6.1.2.1.4.2.0 = INTEGER: 64
Unable to fine-tune mibs for UPS Scheider Electric
Re: Unable to fine-tune mibs for UPS Scheider Electric
You should be able to find an updated MIB list at http://www.apc.com/tools/download/index.cfm - is this for a UPS or a UPS network card?
It's the NIC in the UPS.
Were you able to find an updated MIB list at the above link?
We can assist you in getting your checks working with Nagios, but finding MIBs for a specific device is out of scope for the support we provide.
Here are a few links that may help -
- http://www.apc.com/tools/download/index.cfm
- http://www2.schneider-electric.com/site ... irect=true
- http://www.apc.com/site/support/us/en/f ... irect=true
If you'd like us to set it up for you, we can, however - that falls under custom development and you would need to email sales@nagios.com for a quote.
