I have an old nagios v3.5 server that I'm replacing with a new CentOS 7 server to run nagios v4.1.1. I tried copying over a windows and linux host config files to the new Nagios server and started to get errors. When using the Nagios web client to view the windows host, which previously was running check_nt instead of check_nrpe, the checks are giving the error "Check_nrpe error: Unable to complete SSL handsake". When viewing the linux host the checks are giving the error "Return code 255 is out of bounds".
Looking at that article's explanation of the "Could not complete SSL Handshake" error:
I added my new nagios server IP to allowed hosts in both /usr/local/nagios/etc/nrpe.cfg and /etc/xinetd.d/nrpe
I also added the "per_source" and "instances" lines to /etc/xinetd.d/nrpe
I also made sure SSL is compiled into nrpe.
and still received the "Could not complete SSL Handshake" error.
On EL7 this is commonly because you specified IP addresses in your /etc/xinet.d/nrpe and/or nrpe.cfg file of 127.0.0.1 and 'localhost' resolves to ::1. Try doing /usr/local/nagios/libexec/check_nrpe -H 127.0.0.1
Also - just so that there is no question let's get ps -ef | grep nrpe so that we know if we're coming from inetd or daemonizing.
