Error: Service check command...not defined anywhere!
Re: Error: Service check command...not defined anywhere!
It's just generally wherever you see $ARGx$ it wants some kind of information. Compare our check_users for example. Let me know if you want any help with specifics.
Former Nagios Employee.
me.
me.
Okay, well I got the check_users filled out. But, I don't know what to put for the rest of the arguments for the other service check_commands. Are there examples posted here somewhere?hsmith wrote:It's just generally wherever you see $ARGx$ it wants some kind of information. Compare our check_users for example. Let me know if you want any help with specifics.
Also, I'm getting an error in Nagios, in host status: (No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_ping, ...) failed. errno is 2: No such file or directory
- Box293
- Too Basu
Can you provide the list of the other check_commands please.al_orange wrote:Okay, well I got the check_users filled out. But, I don't know what to put for the rest of the arguments for the other service check_commands. Are there examples posted here somewhere?
Can you create a new thread for this question please along with your host object definition.al_orange wrote:Also, I'm getting an error in Nagios, in host status: (No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_ping, ...) failed. errno is 2: No such file or directory
Here are my check_commands. I only have one with the arguments filled out (Check Swap).
host_name ora_linux7_xen2.xyz.local
service_description CPU Load
check_command check_nrpe!check_load
service_description Total Processes
check_command check_nrpe!check_total_procs
service_description Current Users
check_command check_nrpe!check_users-a '-w 5 -c 10'
service_description SSH Monitoring
check_command check_nrpe!check_ssh
service_description FTP Monitoring
check_command check_nrpe!check_ftp
service_description Check Swap
check_command check_nrpe!check_swap -w 20 -c 10
host_name ora_linux7_xen2.vrcis.local
service_description Check Processes
check_command check_nrpe!check_procs
- Box293
- Too Basu
This screenshot you provided shows the commands already defined with their argument in the nrpe.cfg file.
So you shouldn't need any additional arguments. If you client nrpe.cfg file is different post it here, or perhaps they are defined in /usr/local/nagios/etc/nrpe/common.cfg.
Your screenshot does not show a definition for check_ftp.
I don't recall where I got the screenshot from. I couldn't find the nrpe.cfg file, even after doing a search find / -name "nrpe" -print on the client. On the server, all I found wasBox293 wrote:This screenshot you provided shows the commands already defined with their argument in the nrpe.cfg file.
[root@nagios etc]# find / -name "nrpe" -print
/root/nagios/nrpe-2.15/package/solaris/pkg/nrpe
/root/nagios/nrpe-2.15/src/nrpe
/usr/local/nagios/bin/nrpe
We would need to know where the screenshot came from. That is where check_ftp needs to be defined to work with NRPE.
I forgot where it came from. I don't know where to look. Ugh.rkennedy wrote:We would need to know where the screenshot came from. That is where check_ftp needs to be defined to work with NRPE.
What's the output of ls /usr/lib?
me.
me.
hsmith wrote:What's the output of ls /usr/lib?
[root@XEN1 t]# /usr/lib
-bash: /usr/lib: is a directory
[root@XEN1 t]#
[root@nagios etc]# /usr/lib
-bash: /usr/lib: Is a directory
[root@nagios etc]#
