al_orange
Posts: 55 Joined: Mon Nov 23, 2015 7:27 pm
Post
by al_orange » Tue Jan 12, 2016 5:24 pm
rkennedy wrote: Can you verify the permissions of your libexec folder and post the result?
-rwxr-xr-x 1 nagios nagios 205922 Dec 17 13:30 check_apt
-rwxr-xr-x 1 nagios nagios 2309 Dec 17 13:30 check_breeze
-rwxr-xr-x 1 nagios nagios 210127 Dec 17 13:30 check_by_ssh
lrwxrwxrwx 1 root root 9 Dec 17 13:30 check_clamd -> check_tcp
-rwxr-xr-x 1 nagios nagios 158867 Dec 17 13:30 check_cluster
-r-sr-xr-x 1 root nagios 207752 Dec 17 13:30 check_dhcp
-rwxr-xr-x 1 nagios nagios 224866 Dec 17 13:30 check_disk
-rwxr-xr-x 1 nagios nagios 9348 Dec 17 13:30 check_disk_smb
-rwxr-xr-x 1 nagios nagios 118795 Dec 17 13:30 check_dummy
-rwxr-xr-x 1 nagios nagios 3542 Dec 17 13:30 check_file_age
-rwxr-xr-x 1 nagios nagios 6375 Dec 17 13:30 check_flexlm
lrwxrwxrwx 1 root root 9 Dec 17 13:30 check_ftp -> check_tcp
-rwxr-xr-x 1 nagios nagios 204299 Dec 17 13:30 check_hpjd
-rwxr-xr-x 1 nagios nagios 348270 Dec 17 13:30 check_http
-r-sr-xr-x 1 root nagios 219395 Dec 17 13:30 check_icmp
-rwxr-xr-x 1 nagios nagios 165737 Dec 17 13:30 check_ide_smart
-rwxr-xr-x 1 nagios nagios 15238 Dec 17 13:30 check_ifoperstatus
-rwxr-xr-x 1 nagios nagios 13386 Dec 17 13:30 check_ifstatus
lrwxrwxrwx 1 root root 9 Dec 17 13:30 check_imap -> check_tcp
-rwxr-xr-x 1 nagios nagios 6947 Dec 17 13:30 check_ircd
lrwxrwxrwx 1 root root 9 Dec 17 13:30 check_jabber -> check_tcp
-rwxr-xr-x 1 nagios nagios 183426 Dec 17 13:30 check_load
-rwxr-xr-x 1 nagios nagios 6595 Dec 17 13:30 check_log
-rwxr-xr-x 1 nagios nagios 22730 Dec 17 13:30 check_mailq
-rwxr-xr-x 1 nagios nagios 164911 Dec 17 13:30 check_mrtg
-rwxr-xr-x 1 nagios nagios 166268 Dec 17 13:30 check_mrtgtraf
-rwxr-xr-x 1 nagios nagios 182286 Dec 17 13:30 check_nagios
lrwxrwxrwx 1 root root 9 Dec 17 13:30 check_nntp -> check_tcp
lrwxrwxrwx 1 root root 9 Dec 17 13:30 check_nntps -> check_tcp
-rwxrwxr-x 1 nagios nagios 81470 Nov 18 11:07 check_nrpe
-rwxr-xr-x 1 nagios nagios 211452 Dec 17 13:30 check_nt
-rwxr-xr-x 1 nagios nagios 214711 Dec 17 13:30 check_ntp
-rwxr-xr-x 1 nagios nagios 203908 Dec 17 13:30 check_ntp_peer
-rwxr-xr-x 1 nagios nagios 199073 Dec 17 13:30 check_ntp_time
-rwxr-xr-x 1 nagios nagios 245989 Dec 17 13:30 check_nwstat
-rwxr-xr-x 1 nagios nagios 8926 Dec 17 13:30 check_oracle
-rwxr-xr-x 1 nagios nagios 184583 Dec 17 13:30 check_overcr
-rwxr-xr-x 1 nagios nagios 214756 Dec 17 13:30 check_ping
lrwxrwxrwx 1 root root 9 Dec 17 13:30 check_pop -> check_tcp
-rwxr-xr-x 1 nagios nagios 215914 Dec 17 13:30 check_procs
-rwxr-xr-x 1 nagios nagios 181349 Dec 17 13:30 check_real
-rwxr-xr-x 1 nagios nagios 9642 Dec 17 13:30 check_rpc
-rwxr-xr-x 1 nagios nagios 1465 Dec 17 13:30 check_sensors
lrwxrwxrwx 1 root root 9 Dec 17 13:30 check_simap -> check_tcp
-rwxr-xr-x 1 nagios nagios 272299 Dec 17 13:30 check_smtp
-rwxr-xr-x 1 nagios nagios 264764 Dec 17 13:30 check_snmp
lrwxrwxrwx 1 root root 9 Dec 17 13:30 check_spop -> check_tcp
-rwxr-xr-x 1 nagios nagios 180848 Dec 17 13:30 check_ssh
lrwxrwxrwx 1 root root 9 Dec 17 13:30 check_ssmtp -> check_tcp
-rwxr-xr-x 1 nagios nagios 162647 Dec 17 13:30 check_swap
-rwxr-xr-x 1 nagios nagios 257790 Dec 17 13:30 check_tcp
-rwxr-xr-x 1 nagios nagios 182651 Dec 17 13:30 check_time
lrwxrwxrwx 1 root root 9 Dec 17 13:30 check_udp -> check_tcp
-rwxr-xr-x 1 nagios nagios 195159 Dec 17 13:30 check_ups
-rwxr-xr-x 1 nagios nagios 155189 Dec 17 13:30 check_uptime
-rwxr-xr-x 1 nagios nagios 153879 Dec 17 13:30 check_users
-rwxr-xr-x 1 nagios nagios 2995 Dec 17 13:30 check_wave
drwxr-xr-x 4 nagios nagios 4096 Nov 11 15:40 eventhandlers
-rwxr-xr-x 1 nagios nagios 149404 Dec 17 13:30 negate
-rwxr-xr-x 1 nagios nagios 147032 Dec 17 13:30 urlize
-rwxr-xr-x 1 nagios nagios 1931 Dec 17 13:30 utils.pm
-rwxr-xr-x 1 nagios nagios 2791 Dec 17 13:30 utils.sh
[root@nagios etc]#
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Tue Jan 12, 2016 11:02 pm
Can you please execute this command on your remote linux server that has the NRPE agent installed.
Also, I'm not sure if you've been linked to this troubleshooting guide as it may help:
https://assets.nagios.com/downloads/nag ... utions.pdf
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
al_orange
Post
by al_orange » Wed Jan 13, 2016 12:06 pm
Box293 wrote: rkennedy wrote: Can you verify the permissions of your libexec folder and post the result?
Thanks.
-rwxr-xr-x. 1 nagios nagios 205306 Dec 16 17:04 check_apt
-rwxr-xr-x. 1 nagios nagios 2309 Dec 16 17:04 check_breeze
-rwxr-xr-x. 1 nagios nagios 209511 Dec 16 17:04 check_by_ssh
lrwxrwxrwx. 1 root root 9 Dec 16 17:04 check_clamd -> check_tcp
-rwxr-xr-x. 1 nagios nagios 158243 Dec 16 17:04 check_cluster
-r-sr-xr-x. 1 root nagios 206776 Dec 16 17:04 check_dhcp
-rwxr-xr-x. 1 nagios nagios 224250 Dec 16 17:04 check_disk
-rwxr-xr-x. 1 nagios nagios 9348 Dec 16 17:04 check_disk_smb
-rwxr-xr-x. 1 nagios nagios 118171 Dec 16 17:04 check_dummy
-rwxr-xr-x. 1 nagios nagios 3542 Dec 16 17:04 check_file_age
-rwxr-xr-x. 1 nagios nagios 6375 Dec 16 17:04 check_flexlm
lrwxrwxrwx. 1 root root 9 Dec 16 17:04 check_ftp -> check_tcp
-rwxr-xr-x. 1 nagios nagios 347654 Dec 16 17:04 check_http
-r-sr-xr-x. 1 root nagios 218739 Dec 16 17:04 check_icmp
-rwxr-xr-x. 1 nagios nagios 165121 Dec 16 17:04 check_ide_smart
-rwxr-xr-x. 1 nagios nagios 15238 Dec 16 17:04 check_ifoperstatus
-rwxr-xr-x. 1 nagios nagios 13386 Dec 16 17:04 check_ifstatus
lrwxrwxrwx. 1 root root 9 Dec 16 17:04 check_imap -> check_tcp
-rwxr-xr-x. 1 nagios nagios 6947 Dec 16 17:04 check_ircd
lrwxrwxrwx. 1 root root 9 Dec 16 17:04 check_jabber -> check_tcp
-rwxr-xr-x. 1 nagios nagios 182354 Dec 16 17:04 check_load
-rwxr-xr-x. 1 nagios nagios 6595 Dec 16 17:04 check_log
-rwxr-xr-x. 1 nagios nagios 22730 Dec 16 17:04 check_mailq
-rwxr-xr-x. 1 nagios nagios 164295 Dec 16 17:04 check_mrtg
-rwxr-xr-x. 1 nagios nagios 165652 Dec 16 17:04 check_mrtgtraf
-rwxr-xr-x. 1 nagios nagios 181670 Dec 16 17:04 check_nagios
lrwxrwxrwx. 1 root root 9 Dec 16 17:04 check_nntp -> check_tcp
lrwxrwxrwx. 1 root root 9 Dec 16 17:04 check_nntps -> check_tcp
-rwxrwxr-x. 1 nagios nagios 81470 Nov 18 11:53 check_nrpe
-rwxr-xr-x. 1 nagios nagios 210836 Dec 16 17:04 check_nt
-rwxr-xr-x. 1 nagios nagios 214095 Dec 16 17:04 check_ntp
-rwxr-xr-x. 1 nagios nagios 203292 Dec 16 17:04 check_ntp_peer
-rwxr-xr-x. 1 nagios nagios 198457 Dec 16 17:04 check_ntp_time
-rwxr-xr-x. 1 nagios nagios 245373 Dec 16 17:04 check_nwstat
-rwxr-xr-x. 1 nagios nagios 8926 Dec 16 17:04 check_oracle
-rwxr-xr-x. 1 nagios nagios 183959 Dec 16 17:04 check_overcr
-rwxr-xr-x. 1 nagios nagios 213668 Dec 16 17:04 check_ping
lrwxrwxrwx. 1 root root 9 Dec 16 17:04 check_pop -> check_tcp
-rwxr-xr-x. 1 nagios nagios 215298 Dec 16 17:04 check_procs
-rwxr-xr-x. 1 nagios nagios 180733 Dec 16 17:04 check_real
-rwxr-xr-x. 1 nagios nagios 9642 Dec 16 17:04 check_rpc
-rwxr-xr-x. 1 nagios nagios 1465 Dec 16 17:04 check_sensors
lrwxrwxrwx. 1 root root 9 Dec 16 17:04 check_simap -> check_tcp
-rwxr-xr-x. 1 nagios nagios 271083 Dec 16 17:04 check_smtp
lrwxrwxrwx. 1 root root 9 Dec 16 17:04 check_spop -> check_tcp
-rwxr-xr-x. 1 nagios nagios 180232 Dec 16 17:04 check_ssh
lrwxrwxrwx. 1 root root 9 Dec 16 17:04 check_ssmtp -> check_tcp
-rwxr-xr-x. 1 nagios nagios 162031 Dec 16 17:04 check_swap
-rwxr-xr-x. 1 nagios nagios 257174 Dec 16 17:04 check_tcp
-rwxr-xr-x. 1 nagios nagios 182035 Dec 16 17:04 check_time
lrwxrwxrwx. 1 root root 9 Dec 16 17:04 check_udp -> check_tcp
-rwxr-xr-x. 1 nagios nagios 194543 Dec 16 17:04 check_ups
-rwxr-xr-x. 1 nagios nagios 154573 Dec 16 17:04 check_uptime
-rwxr-xr-x. 1 nagios nagios 153263 Dec 16 17:04 check_users
-rwxr-xr-x. 1 nagios nagios 2995 Dec 16 17:04 check_wave
-rwxr-xr-x. 1 nagios nagios 148788 Dec 16 17:04 negate
-rwxr-xr-x. 1 nagios nagios 145944 Dec 16 17:04 urlize
-rwxr-xr-x. 1 nagios nagios 1931 Dec 16 17:04 utils.pm
-rwxr-xr-x. 1 nagios nagios 2791 Dec 16 17:04 utils.sh
hsmith
Agent Smith
Posts: 3539 Joined: Thu Jul 30, 2015 11:09 am
Post
by hsmith » Wed Jan 13, 2016 1:41 pm
I sent you a PM.
Former Nagios Employee.
me.
hsmith
Agent Smith
Post
by hsmith » Wed Jan 13, 2016 3:30 pm
This one has been resolved. Things that needed to be fixed:
The commands were using arguments inside of the services.cfg file, but dont_blame_nrpe was set to 0 on the remote machine.
The remote machine was missing definitions for a couple of the commands that nagios was checking for.
me.
