Hello, I would like to know how to pnp4nagios generate two graphs at the same time, one for type and another kbps to mbps.
My left in Nagios is so
# bash -x check_traffic_sentinela_rx_cidade
cd /home/nagios
rm -rf check_traffic_sentinela_rx_cidade.txt
outputSSH=$ ssh [email protected] "/interface monitor-traffic interface=interface-sentinela once"|grep rx-bits-per-second|sed 's/%//' > check_traffic_sentine$
livre=$(grep Mbps check_traffic_sentinela_rx_cidade.txt)
output=$(sed 's/rx-bits-per-second: //;s/Mbps//;s/kbps//;s/bps//g' check_traffic_sentinela_rx_cidade.txt)
output=$(echo $output | cut -d . -f 1 )
mostra=$(sed 's/rx-bits-per-second://g' check_traffic_sentinela_rx_cidade.txt)
if [ -z "$livre" ] ; then
livre2=$(grep k check_traffic_sentinela_rx_cidade.txt)
livre2=$(grep . check_traffic_sentinela_rx_cidade.txt)
if [ -n "livre2" ]; then
echo " $output"kbps" | rx=$output"kbps" "
exit 0;
elif [ -z "livre2" ] ; then
echo " 0kbps | rx=0kbps "
exit 0;
fi
elif [ -n "$livre" ]; then
if [ $output -ge 20 ]; then
echo " $output"Mbps" | rx=$output"Mbps" "
exit 2;
else
echo " $output"Mbps" | rx=$output"Mbps""
exit 0;
fi
else
echo " ERROR - SEM RETORNO NO ARQUIVO check_traffic_sentinela_rx_cidade.txt"
exit 1;
fi
exit 3;
I would like to generate a graph for kbps and another for mbps
pnp4nagios generating graphs
Re: pnp4nagios generating graphs
Can you provide clarification for what you're trying to do? What is the file that you have posted?
alexprinou
this file and to monitor network traffic mikrotik equipment, I want seprar the graphics in kbps and mbps mbps look like on a graph and in other kbps.
Where did you find the above script that is posted? It doesn't look to be returning perfdata.
alexprinou
This script was that I developed .
Returns perfdata , see the attached image
- Box293
- Too Basu
You'll need to create a pnp template that will calculate that the value is in mbps as your plugin is returning kbps.
I did a talk about this at the Nagios World Conference, you can watch it here:
https://www.youtube.com/watch?v=kqA2KcpUFg4
http://www.slideshare.net/nagiosinc/tro ... and-graphs
It might take a while to get your head around it all. I suggest watching the presentation without any distractions as it can get complicated.
