Hello Expert,
Need help in writing the script for Data Protector sessions list. Appreciate any help with script which can list me Data Protector session using nagios webpage html.
DP_Sess_Hist.php
- Box293
- Too Basu
Re: DP_Sess_Hist.php
Can you provide some more information on exactly what you're trying and what you've already done?
syedfurquanalam
I was thinking of having a script which can lists all my sessions of data protector using nagios.php. In sessions listing options I need the o/p in the form of as attached.
Cuurently I have scripts like schedules in "/var/www/html/DP_Schedules.php" which will lists all the schedule. Similarly i want for sessions.
Regards,
Regards,
Nagios.docx- Format for listing the DP session in Nagios
- (13.03 KiB) Downloaded 192 times
Are you able to pull this data from somewhere currently over command line? What are you referring to when you mention 'data protector'?
