Running './4-firewall'...
The service command supports only basic LSB actions (start, stop, restart, try-restart, reload, force-reload, status). For other actions, please try to use systemctl.
FirewallD is not running
RESULT=252
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './4-firewall'
yum -y install wget openssl-devel
cd /tmp
wget http://assets.nagios.com/downloads/nagiosxi/agents/linux-nrpe-agent.tar.gz
tar xzf linux-nrpe-agent.tar.gz
cd linux-nrpe-agent
./fullinstall
