Web Upgrade Failed
cockraml
Web Upgrade Failed
Post by cockraml »
I attempted to upgrade the nagios software on a RHEL6 system using the web interface. I do not see any issues in the log, but it says the update was not successful on the webpage above the log.
Attached is my upgrade log.
hsmith
Agent Smith
Re: Web Upgrade Failed
Post by hsmith »
The log says it completed successfully. There is currently a visual bug that says it didn't work, but it did. Can you please check for upgrades again and see if it finds any?
Former Nagios Employee.
me.
cockraml
Post by cockraml »
It says it is up to date after the upgrade.
The actual message after the upgrade says "The update did not complete successfully. Please try updating manually."
hsmith
Agent Smith
Post by hsmith »
This should be fixed in 5.2.3, you may see the error after upgrading to that version when it is released, but you probably won't see it when upgrading to 5.2.4 or whatever is next! This has been a pesky bug to squash, but at least it's working for now.
me.
cockraml
Post by cockraml »
Just so I am clear, I can do the web upgrade and ignore the below message? I do not have to do it manually?
hsmith
Agent Smith
Post by hsmith »
Correct, it should be just fine.
me.
cockraml
Post by cockraml »
Great! Thank you for your quick response.
hsmith
Agent Smith
Post by hsmith »
Are we free to close this thread since this is working for you?
me.
cockraml
Post by cockraml »
Yes. Thank you again.
bwallace
Post by bwallace »
Glad we were able to help. We'll lock this thread now and feel free to open another should you require assistance with anything else.
