When I am doing a integration test with nagios, something weird happens.
Here is the situation:
1. Nagios Configuration
# grep log_notification /usr/local/nagios/etc/nagios.cfg
log_notifications=1
#grep enable_notifications /usr/local/nagios/etc/nagios.cfg
enable_notifications=1Code: Select all
define contact {
contact_name jone.doe
host_notifications_enabled 1
service_notifications_enabled 1
host_notification_period 7x24
service_notification_period 7x24
host_notification_options d,u,r,f,s,n
service_notification_options w,u,c,r,f,s,n
email [email protected]
host_notification_commands notify_service_by_state
service_notification_commands notify_service_by_state
host_name localhost
address localhost
max_check_attempts 1
check_period 7x24
active_checks_enabled 1
passive_checks_enabled 0
check_command check_host_alive
host_name localhost
service_description check_the_process_count_of_the_local_machine
check_command check_local_procs!10!20!RSZDT
max_check_attempts 3
check_interval 3
retry_interval 1
notification_interval 3
check_period 7x24
contacts john.doe
}Code: Select all
define timeperiod{
timeperiod_name 7x24
alias 7x24
monday 00:00-24:00
tuesday 00:00-24:00
wednesday 00:00-24:00
thursday 00:00-24:00
friday 00:00-24:00
saturday 00:00-24:00
sunday 00:00-24:00
command_name check_local_procs
command_line $USER1$/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
command_name notify_service_by_state
command_line /usr/local/nagios/etc/scripts/notify.py "$SERVICESTATE$" "$CONTACTEMAIL$" "$CONTACTADDRESS1$" "$NOTIFICATIONTYPE$" "$HOSTALIAS$" "$SERVICEDESC$" "$HOSTADDRESS$" "$SERVICEOUTPUT$" "$LONGDATETIME$"
command_name check_host_alive
command_line $USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
}Code: Select all
#!/usr/bin/python
#coding:utf-8
import codecs
import sys
import urllib
import commands
import smtplib
from email.mime.text import MIMEText
from email.header import Header
import time
fi = codecs.open('/data/appdatas/logs/message.log', 'a' , encoding='utf-8')
fi.write("=======Begin Log\n");
fi.write("Notify\n");
fi.write(time.strftime('%Y-%m-%d %H:%M:%S') + "\n");
fi.write(sys.argv[1]+ "\n");
fi.write("End Log=========\n");
fi.close()Code: Select all
chmod +777 to the log_fileAnd
chmod +x notify.pyAs you can see the check_local_proc command. This command will return a code 2 as it executed.
In the nagios.log file, I have see these logs:
[1449588806] SERVICE ALERT: localhost;check_the_process_count_of_the_local_machine;CRITICAL;SOFT;1;PROCS CRITICAL: 423 processes with STATE = RSZDT
[1449588866] SERVICE ALERT: localhost;check_the_process_count_of_the_local_machine;CRITICAL;SOFT;2;PROCS CRITICAL: 423 processes with STATE = RSZDT
[1449588926] SERVICE ALERT: localhost;check_the_process_count_of_the_local_machine;CRITICAL;HARD;3;PROCS CRITICAL: 423 processes with STATE = RSZDTBut there's no log in the message.log file (no execution of the notify.py).
Would you please help me with this problem.
This is the Url on stackoverflow.com
http://stackoverflow.com/questions/3416 ... ifications
