Double Alerts
perric
Double Alerts
Post by perric »
I did a quick check through the forums and didn't see anything on this. I have a service check setup, which provides CRITICAL and WARNING alerts when a value hits the threshold. This works great. See example of the alert below. However, each time, I also get an alert on the host object and the alert for the host is always "Up" and "Ok" with the latest rta and % lost. Is there a way to have it only alert on the service and not the host? I feel like I am missing a setting here, but cannot find it.
Nagios has detected a problem with this service.
Type: PROBLEM
Service: Traffic
Host: Router
IP: 10.192.1.1
State: WARNING
Info: WARNING - Traffic Exceeds 75 Percent - 78
Respond: http://nagios/nagiosxi/rr.php?uid=63-71 ... a13322c199
Nagios URL: http://nagios/nagiosxi/
Date/Time: 2015-12-09 14:59:04
David
Re: Double Alerts
You can always set up what type of notifications you would like to receive for this particular host under the CCM.
Host - notification options
This directive is used to determine when notifications for the host should be sent out. Valid options are a combination of one or more of the following:
d = send notifications on a DOWN state,
u = send notifications on an UNREACHABLE state,
r = send notifications on recoveries (OK state),
f = send notifications when the host starts and stops flapping, and
s = send notifications when scheduled downtime starts and ends.
If you do not specify any notification options, Nagios will assume that you want notifications to be sent out for all possible states.
Example: If you specify d,r in this field, notifications will only be sent out when the host goes DOWN and when it recovers from a DOWN state.
Parameter name: notification_options
Required: yes
Re: Double Alerts
Post by Box293 »
Can you post the config for the service please.
CCM > Monitoring > Services
Click the floppy disk icon and paste the text config here please.
perric
Re: Double Alerts
Post by perric »
lmiltchev - thanks for your response. You provided host alert settings, but this is a service check. To rephrase my question, why am I receiving "host" alerts, when my "service" check reports a WARNING?
Box293 - Below is the config for the service, as well as the details for two nested templates being used with the service.
David
# Service configuration file
# Created by: Nagios Core Config Manager 2.3.3
# Date:	      2015-12-10 10:41:55
# Version:    Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
	host_name			clsanfw01
	service_description		clsanfw01_InternetUtil_Entel4Mbps
	use				@clsan_net_master_template
	display_name			clsanfw01_InternetUtil_Entel4Mbps
	servicegroups			Latam_Bandwidth_Internet
	check_command			check_cisco_bw_util!Pern0dRO!4!15!!!!!
	register			1
# END OF FILE
Here are the associated templates for this service from the Service template configuration file... I omitted most services that were not used.
# Service template configuration file
# Date:	      2015-12-10 10:44:12
       name                          		@clsan_net_master_template
       service_description           		Santiago CL Service Template
       use                           		@net_master_9x5
       register                    		0
       name                          		@net_master_9x5
       service_description           		Network_Master_9x5 for Services
       initial_state                 		o
       max_check_attempts            		3
       check_interval                		1
       retry_interval                		1
       active_checks_enabled         		1
       passive_checks_enabled        		1
       check_period                  		 NET_Critical 24x7x365
       notification_interval         		1440
       first_notification_delay      		1
       notification_period           		 NET_Critical 24x7x365
       notification_options          		w,c,u,r,s,
       notifications_enabled         		1
       contact_groups                		NET_Alert_Group_9x5
       register                    		0
Reason: Please use [code][/code] tags around long output
Re: Double Alerts
and showed us the service notification. Can you also show us the actual host notification, along with the config of the contact, receiving it (& all associated commands, templates, etc.)? Thanks!
perric
Re: Double Alerts
Post by perric »
Below are the details of the host object (for this service), the host templates, contact group/contact and check command.
David
# Host configuration file
# Date:	      2015-12-10 13:03:25
define host {
	host_name			clsanfw01
	alias				Santiago CL Firewall
	address				192.168.0.1
	parents				clsanparent1
	hostgroups			clsan_network
	_xiwizard			snmp
	register			1
# END OF FILE
[b]Template details...[/b] - non relevant templates were removed.
# Host template configuration file
# Date:	      2015-12-10 13:05:06
define host {
       alias                         		Santiago, CL Network Settings Template
       use                           		@network_master_9x5
       initial_state                 		o
       register                    		0
define host {
       name                          		@network_master_9x5
       alias                         		network_master_9x5
       check_command                 		check-host-alive!!!!!!!!
       initial_state                 		o
       check_interval                		1
       retry_interval                		1
       notification_options          		d,r,s,
       register                    		0
[b]Contact Group and Contact Details[/b]
# Contact Group configuration file
# Date:	      2015-12-10 13:12:08
define contactgroup {
	contactgroup_name             		NET_Alert_Group_9x5
	alias                         		NET_Alert_Group_9x5
	members                       		ddutt,ddutt_pager,jligot01,jwang01
# Contact configuration file
# Date:	      2015-12-10 13:13:11
define contact {
	contact_name                  		ddutt
	alias                         		David Dutt
	host_notifications_enabled    		1
	service_notifications_enabled 		1
	host_notification_period      		 NET_Critical 24x7x365
	service_notification_period   		 NET_Critical 24x7x365
	host_notification_options     		d,u,r,f,s,
	service_notification_options  		w,u,c,r,f,s,
	host_notification_commands    		NET_xi_host_notification_handler
	service_notification_commands 		NET_xi_host_notification_handler,xi_service_notification_handler
	email                         		[email protected]
	pager                         		9146488046
	use                           		xi_contact_generic
# Check command configuration file
# Date:	      2015-12-10 13:16:08
       command_name                  		check_cisco_bw_util
       command_line                  		$USER1$/check_cisco_bw_util.sh $HOSTADDRESS$ $ARG1$ $ARG2$ $ARG3$
Re: Double Alerts
It seems like the "ddutt" contact is using both, the host & service notification handler defined for "service_notification_commands"...
define contact {
contact_name ddutt
alias David Dutt
pager 9146488046
perric
Re: Double Alerts
Post by perric »
I want to have users like ddutt to receive both host and service notifications. I am not seeing how this is related to the issue?
If there is a service check (for port or interface bandwidth utilization) that returns a WARNING, why should the host send an alert on this same service issue? My hosts are doing an ICMP or ping check, which is completely different and unrelated. Doesn't make sense to receive both service and host alerts, when only the service returns a WARNING and the host check is fine. For reference, here are the alerts received when bandwidth exceeds a threshold:
SERVICE ALERT
Nagios has detected this service has recovered.
Type: RECOVERY
Service: brresfw01_InternetUtil_Hotwave_4Mbps
Host: brresfw01
IP: 192.168.0.1
State: OK
Info: OK - Traffic Normal
Date/Time: 2015-12-10 14:00:29
HOST ALERT
Nagios has detected this host has recovered.
Notification Type: RECOVERY
Host: brresfw01
State: UP
Address: 192.168.0.1
Info: OK - 192.168.0.1: rta 148.518ms, lost 0%
Respond: http://nagios/nagiosxi/rr.php?uid=63-67 ... a13322c199
David
perric
Re: Double Alerts
Post by perric »
Nevermind. I didn't see that I had both Host and Service handlers on the service notification configuration. I thought you were pointing out something else.
Thanks for your help. Please close the issue.
