configuration save impossible
pouda
Post by pouda »
Hi all
So when i tried to save new configuration on my Nagiosxi server i have this error message below
my installation is a fresh installation, nothing have been added or modified ...
Someone coould help me ?
thx you VM
pouda
Re: configuration save impossible
Post by pouda »
please help?
nscott
Post by nscott »
pouda,
There should be a View Configuration Snapshot link, click that. Then there should be a list of configurations and the dates they were applied. The lastest one should be red. Can you click on the paper icon associated with that config? This will download a text file that will say why the apply config failed. Post the log here.
Nicholas Scott
pouda
Post by pouda »
no since the beginning i'm not able to save the configuration ... so no previous snapshot to restore ... but this problem is now solved ... i've resinstalled once again my server and it works properly now ....
MathieuS
Post by MathieuS »
Try this when you have that problem again
mguthrie
Post by mguthrie »
Nagios XI will automatically roll back to the last known working configuration if a bad config is detected. Using the Configuration Snapshots page allows you to view the bad snapshot, while allowing the monitoring engine to keep running. See below for more explanation.
http://support.nagios.com/wiki/index.ph ... n_Problems
pouda
Post by pouda »
i found the problem ...
I'm using a proxy for Wget packages retreiving and i set some option in the config file/etc/wgetrc for using proxy and authentication automaticaly ... after what Nagios services are not able to save its own configuration ... i remove these line in /etc/wgetrc and nagios services worked properly again ...
:lol: :lol:
mguthrie
Post by mguthrie »
Ok, good deal. Thanks for the update!
