No data showing
djcomber
No data showing
Post by djcomber »
I'm seeing traffic but no data
When a report is run I get and erro
I've recompiled nfdump as suggested in another forum post https://support.nagios.com/forum/viewto ... 29&t=35646
still no good.
eloyd
Cool Title Here
Re: No data showing
Post by eloyd »
Try running nfdump from the command line, as the nagios user, and without the "2> /dev/null" part (which eliminates the display of errors). That will likely tell you what's going wrong.
Re: No data showing
You can look at the following log file to see if there are any errors that can help out.
/usr/local/nagiosna/var/backend.log
You can post it if you need help.
djcomber
Re: No data showing
Post by djcomber »
eloyd wrote:Try running nfdump from the command line, as the nagios user, and without the "2> /dev/null" part (which eliminates the display of errors). That will likely tell you what's going wrong.
thanks tried the command previosuly but didn't remove the "2> /dev/null" and got nothing
command
 /usr/local/bin/nfdump -M '/usr/local/nagiosna/var/NUGSHORTRT01/flows/' -R . -t '2015/12/22.13:03:50-2015/12/23.13:03:49' -N -n '5' -s 'srcip/bytes' -o 'csv'
response
Open file '/usr/local/nagiosna/var/NUGSHORTRT01/flows/._nfdump-1.6.13': bad magic: 0x500
djcomber
Re: No data showing
Post by djcomber »
tgriep wrote:You can look at the following log file to see if there are any errors that can help out.
used
cat /usr/local/nagiosna/var/backend.log | grep ERROR
No Errors in the log.
No Warnings
plenty of debug and info
Re: No data showing
Can you run the following on the NA system and post the output here in Code Wraps?
ls -alR /usr/local/nagiosna/var
The bad magic message could be a failing hard drive or a corrupt file.
eloyd
Cool Title Here
Re: No data showing
Post by eloyd »
I'm concurring with disk/file corruption. Is this on a physical machine or virtual machine? Virtual machine should never see a bad magic number, but it's possible.
hsmith
Agent Smith
Re: No data showing
Post by hsmith »
Thanks Eric!
Former Nagios Employee.
me.
djcomber
Re: No data showing
Post by djcomber »
The output was too big for a single cut and paste so I attached the file.
NNA is running on a virtual, VmWare 5.1. I originally deployed the OVA but it had weird date vs hwdate issues even when NTP was setup. so I build NNA manually on a manual centos6 a fresh install build.
Then I rebuild nfdump when I received this error. so you'll see nfdump source
Re: No data showing
It looks like the nfdump package was downloaded to that flows folder and is causing the issue.
Lets remove them and see if that resolves the issue. Login to the system as root and run the following to remove those files and folders.
rm -fr /usr/local/nagiosna/var/NUGSHORTRT01/flows/._nfdump-1.6.13
rm -fr /usr/local/nagiosna/var/NUGSHORTRT01/flows/nfdump-1.6.13
Wait 20 minutes and see if the error is gone.
Let us know how it works for you.
