Nagios Core Installation
nalamada
Post by nalamada »
We are conducting a POC for Nagios Monitoring, We would like to install Nagios XI and I have started with Nagios Core.
We are doing these installs on a empty Linux Sandbox RHEL 5.5 64 bit,4vCPU,4GB RAM,OS Partition: 25 GB
I have tried to installed Nagios Core (using the source version) using FullInstall and also tried the individual steps, kindly suggest how these could be rectified or what should be the correct way. I heard installing from a Image but cannot find the correct documentation for this.
Attached are the logs for this.
Raghu
runlog.txt
(244.55 KiB) Downloaded 115 times
nscott
Re: Nagios Core Installation
Post by nscott »
It looks like it is unable to install the RPMforge repo for some reason. Try manually installing it via these instructions:
http://wiki.centos.org/AdditionalResour ... 4998926a1b
And rerun the full install script.
Nicholas Scott
