This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
drug
Posts: 86 Joined: Wed Apr 03, 2013 3:19 pm
Post
by drug » Mon Jan 11, 2016 10:53 am
In an attempt to reinstall Nagios XI 5 on a CentOS 7 system, I ran the uninstall.xi.sh successfully and removed the /etc/httpd directory. Subsequently, I downloaded the xi-5.2.3 tarball and executed ./fullinstall.sh as root after changing to the /tmp/nagiosxi directory. However, the installation fails:
Running './E-importnagiosql'...
./E-importnagiosql: line 21: killall: command not found
Applying patches to Apache configs for Apache 2.4.x syntax...
Redirecting to /bin/systemctl start httpd.service
Sleeping...
NOTE: If prompted, enter the MySQL root password
NagiosQL database appears OK - continuing...
NDOUtils database appears OK - continuing...
Found config files to import - continuing...
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O nagiosql.login--2016-01-11 15:36:14-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2016-01-11 15:36:14 ERROR 404: Not Found.
NAGIOSQL LOGIN FAILED!
RESULT=1
INSTALLATION ERROR!
Could there be something that was not properly removed from the previous install that was overlooked? Please find install.log attached.
drug
Post
by drug » Mon Jan 11, 2016 12:40 pm
Executing the following allowed the installation to succeed:
uninstall_xi.sh
yum remove php && yum remove php-common
fullinstall
bwallace
Posts: 1145 Joined: Tue Nov 17, 2015 1:57 pm
Post
by bwallace » Mon Jan 11, 2016 12:51 pm
Thanks for sharing the solution, I'll go ahead and lock this thread now.
Be sure to check out the
Knowledgebase for helpful articles and solutions!
