How do I expand the virtual disk of Network Analyzer VM?
bmunger
Post by bmunger »
Is there a documented procedure on how to expand the size of the disk of the Network Analyzer virtual machine? The VM is running on VMWare so I can expand the disk easily, but how do I make the operating system utilize it correctly without messing something up? If there is a document on this, I can't find it...
snapon_admin
Re: How do I expand the virtual disk of Network Analyzer VM?
Post by snapon_admin »
Typically you can follow the documentation for resizing the disk in XI for this. Can you run this and paste the output?
df -h
If your VM isn't using LVM (like ours isn't for some reason) then you may have to mount an ISO of a disk partition utility like gparted and resize it that way. I literally resized our NNA server's virtual disk like an hour ago with this method. Whichever method you use don't forget to make backups!
hsmith
Agent Smith
Post by hsmith »
The NNA ova isn't running LVM, the developers are aware of this, but I do not know when/if it is on the roadmap. Did you install from ova?
Former Nagios Employee.
me.
bmunger
Post by bmunger »
OK - I figured this out, using the Nagios XI re-sizing document as a guide. I was initially thrown off because LVM is not in use. It was actually pretty simple.
The steps are:
Resize in VMWare
run fdisk on virtual disk /dev/sda
Delete partition
Re-create partition using the end of the disk as the last cylinder
reboot
Then the resize command has to be run:
resize2fs /dev/sda1
That is pretty much it.
You got it. The guide describes in an LVM environment. Thanks for the contribution @snapon_admin!
Am I good to mark this thread as resolved, and close it out?
