need critical_max_check_attempts
rexconsulting
Post by rexconsulting »
One of the problems with the CPU check is that sometimes 100% CPU utilization is OK. Generally LOADAVE is a much better indicator of system that's saturated and thus a more worthy plugin for notification sending.
CPU checks can cause too many notifications because of the ceiling. You can't set a threshold greater than 100% utilization (or 0% idle, is it also may be measured).
So I'm thinking it would be good to have a critical_max_check_attempts for CPU. This way, we could have a state change based on number of consecutive non-OK checks, and not necessarily the value of the return result.
I guess this could be achieved with a smart plugin, that tracked its own attempt count, returning 2 when it achieved critical_max_check_attempts. But also may be useful as a server config. What do you think ?
CP
Chris Paul
Rex Consulting, Inc
5652 Florence Terrace, Oakland, CA 94611
email: [email protected]
web: http://www.rexconsulting.net
phone, toll-free: +1 (888) 403-8996 ext 1
Re: need critical_max_check_attempts
I think this is the job of a plugin, not the nagios process itself. If it were to be implemented in the nagios process, we would have a near-endless amount of config options for every plugin, and some people may not even use a given plugin. This leads to a lot of clutter in the configs.
