Nagios XI HTTPS Issue
tigerpeng
Post by tigerpeng »
Could you help on trouble shooting?
I followed https://assets.nagios.com/downloads/nag ... s%20XI.pdf, to setup HTTPS for my newly installed Nagios XI. However, the https://nagiosxi.connectedcarhub.com/ page looks strange and https://nagiosxi.connectedcarhub.com/nagiosxi/ return 403 Forbidden. (http://nagiosxi.connectedcarhub.com/nagiosxi/ works as expected).
The /var/log/httpd/error_log have record as below:
[Fri Jan 22 23:07:34.539295 2016] [authz_core:error] [pid 2564] [client 207.238.125.2:10156] AH01630: client denied by server configuration: /usr/local/nagiosxi/html/, referer: https://nagiosxi.connectedcarhub.com/
[root@nagiosxi conf]# ls -ld  /usr/local/nagiosxi/html
drwxr-xr-x. 19 nagios nagios 4096 Jan  5 19:09 /usr/local/nagiosxi/html
[root@nagiosxi conf]# ls -l  /usr/local/nagiosxi/html
total 384
drwxr-xr-x.  2 nagios nagios     37 Jan  5 19:09 about
drwxr-xr-x.  2 nagios nagios   4096 Jan  5 19:09 account
drwxr-xr-x.  2 nagios nagios     69 Jan  5 19:09 addons
drwxr-xr-x.  2 nagios nagios   4096 Jan  5 19:09 admin
-rwxr-xr-x.  1 nagios nagios  26932 Jan  5 19:09 ajaxhelper.php
-rwxr-xr-x.  1 nagios nagios   1652 Jan  5 19:09 ajaxproxy.php
drwxr-xr-x.  4 nagios nagios     30 Jan  5 19:09 api
drwxr-xr-x.  3 nagios nagios     66 Jan  5 19:09 backend
drwxr-xr-x.  3 nagios nagios   4096 Jan  5 19:09 config
-rwxr-xr-x.  1 nagios nagios   8699 Jan  5 19:09 config.inc.php
drwxr-xr-x.  2 nagios nagios     78 Jan  5 19:09 dashboards
drwxr-xr-x.  4 nagios nagios     71 Jan  5 19:09 db
drwxr-xr-x.  3 nagios nagios     20 Jan  5 19:09 downloads
drwxr-xr-x.  2 nagios nagios   4096 Jan  5 19:09 help
drwxr-xr-x.  4 nagios nagios   8192 Jan  5 19:09 images
drwxr-xr-x. 11 nagios nagios   4096 Jan  5 19:09 includes
-rwxr-xr-x.  1 nagios nagios    884 Jan  5 19:09 index.php
-rwxr-xr-x.  1 nagios nagios  10086 Jan  5 19:09 install.php
-rwxr-xr-x.  1 nagios nagios 246100 Jan  5 19:09 login.php
-rw-r--r--.  1 nagios nagios   2303 Jan  5 19:09 loginsplash.inc.php
drwxr-xr-x.  2 nagios nagios     22 Jan  5 19:09 perfgraphs
drwxr-xr-x.  2 nagios nagios   4096 Jan  5 19:09 reports
-rw-r--r--.  1 nagios nagios  20509 Jan  5 19:09 rr.php
-rwxr-xr-x.  1 nagios nagios  12206 Jan  5 19:09 suggest.php
drwxr-xr-x.  2 nagios nagios     77 Jan  5 19:09 tools
-rwxr-xr-x.  1 nagios nagios   2010 Jan  5 19:09 upgrade.php
drwxr-xr-x.  2 nagios nagios     54 Jan  5 19:09 views
hsmith
Agent Smith
Re: Nagios XI HTTPS Issue
Post by hsmith »
Can we see a couple of files?
cat /etc/httpd/conf.d/nagiosxi.conf
cat /etc/httpd/conf/httpd.conf
Former Nagios Employee.
me.
tigerpeng
Post by tigerpeng »
It is on RedHat (the SeLinux is disabled)
  • /etc/httpd/conf.d/nagiosxi.conf
    #NameVirtualHost *:443
    <VirtualHost *:80>
    <Directory "/usr/local/nagiosxi/html">
    #  SSLRequireSSL
       Options None
       AllowOverride None
       Order allow,deny
       Allow from all
    #  Order deny,allow
    #  Deny from all
    #  Allow from 127.0.0.1
    #   AuthName "Nagios XI"
    #   AuthType Basic
    #   AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users
    #   Require valid-user
       Require all granted
    </Directory>
    </VirtualHost>
    <VirtualHost *:443>
            SSLEngine on
            SSLCertificateFile /etc/pki/tls/certs/connectedcarhub.com.crt
            SSLCertificateKeyFile /etc/pki/tls/private/connectedcarhub.com.key
            AllowOverride All
            </Directory>
    </VirtualHost>
    Alias /nagiosxi "/usr/local/nagiosxi/html"
    <IfModule mod_rewrite.c>
    RewriteEngine On
    RewriteCond %{REQUEST_FILENAME} !-f
    RewriteCond %{REQUEST_FILENAME} !-d
    RewriteRule nagiosxi/api/v1/(.*)$ /usr/local/nagiosxi/html/api/v1/index.php?request=$1 [QSA,NC,L]
    </IfModule>
  • /etc/httpd/conf/httpd.conf (only added the very last line to the default file)
    # This is the main Apache HTTP server configuration file.  It contains the
    # configuration directives that give the server its instructions.
    # See <URL:http://httpd.apache.org/docs/2.4/> for detailed information.
    # In particular, see
    # <URL:http://httpd.apache.org/docs/2.4/mod/directives.html>
    # for a discussion of each configuration directive.
    # Do NOT simply read the instructions in here without understanding
    # what they do.  They're here only as hints or reminders.  If you are unsure
    # consult the online docs. You have been warned.
    # Configuration and logfile names: If the filenames you specify for many
    # of the server's control files begin with "/" (or "drive:/" for Win32), the
    # server will use that explicit path.  If the filenames do *not* begin
    # with "/", the value of ServerRoot is prepended -- so 'log/access_log'
    # with ServerRoot set to '/www' will be interpreted by the
    # server as '/www/log/access_log', where as '/log/access_log' will be
    # interpreted as '/log/access_log'.
    # ServerRoot: The top of the directory tree under which the server's
    # configuration, error, and log files are kept.
    # Do not add a slash at the end of the directory path.  If you point
    # ServerRoot at a non-local disk, be sure to specify a local disk on the
    # Mutex directive, if file-based mutexes are used.  If you wish to share the
    # same ServerRoot for multiple httpd daemons, you will need to change at
    # least PidFile.
    ServerRoot "/etc/httpd"
    # Listen: Allows you to bind Apache to specific IP addresses and/or
    # ports, instead of the default. See also the <VirtualHost>
    # directive.
    # Change this to Listen on specific IP addresses as shown below to
    # prevent Apache from glomming onto all bound IP addresses.
    #Listen 12.34.56.78:80
    Listen 80
    # Dynamic Shared Object (DSO) Support
    # To be able to use the functionality of a module which was built as a DSO you
    # have to place corresponding `LoadModule' lines at this location so the
    # directives contained in it are actually available _before_ they are used.
    # Statically compiled modules (those listed by `httpd -l') do not need
    # to be loaded here.
    # Example:
    # LoadModule foo_module modules/mod_foo.so
    Include conf.modules.d/*.conf
    # If you wish httpd to run as a different user or group, you must run
    # httpd as root initially and it will switch.
    # User/Group: The name (or #number) of the user/group to run httpd as.
    # It is usually good practice to create a dedicated user and group for
    # running httpd, as with most system services.
    User apache
    Group apache
    # 'Main' server configuration
    # The directives in this section set up the values used by the 'main'
    # server, which responds to any requests that aren't handled by a
    # <VirtualHost> definition.  These values also provide defaults for
    # any <VirtualHost> containers you may define later in the file.
    # All of these directives may appear inside <VirtualHost> containers,
    # in which case these default settings will be overridden for the
    # virtual host being defined.
    # ServerAdmin: Your address, where problems with the server should be
    # e-mailed.  This address appears on some server-generated pages, such
    # as error documents.  e.g. [email protected]
    ServerAdmin root@localhost
    # ServerName gives the name and port that the server uses to identify itself.
    # This can often be determined automatically, but we recommend you specify
    # it explicitly to prevent problems during startup.
    # If your host doesn't have a registered DNS name, enter its IP address here.
    #ServerName http://www.example.com:80
    # Deny access to the entirety of your server's filesystem. You must
    # explicitly permit access to web content directories in other
    # <Directory> blocks below.
    <Directory />
        AllowOverride none
        Require all denied
    </Directory>
    # Note that from this point forward you must specifically allow
    # particular features to be enabled - so if something's not working as
    # you might expect, make sure that you have specifically enabled it
    # below.
    # DocumentRoot: The directory out of which you will serve your
    # documents. By default, all requests are taken from this directory, but
    # symbolic links and aliases may be used to point to other locations.
    DocumentRoot "/var/www/html"
    # Relax access to content within /var/www.
    <Directory "/var/www">
        AllowOverride None
        # Allow open access:
        Require all granted
    </Directory>
    # Further relax access to the default document root:
    <Directory "/var/www/html">
        # Possible values for the Options directive are "None", "All",
        # or any combination of:
        #   Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
        # Note that "MultiViews" must be named *explicitly* --- "Options All"
        # doesn't give it to you.
        # The Options directive is both complicated and important.  Please see
        # http://httpd.apache.org/docs/2.4/mod/core.html#options
        # for more information.
        Options Indexes FollowSymLinks
        # AllowOverride controls what directives may be placed in .htaccess files.
        # It can be "All", "None", or any combination of the keywords:
        #   Options FileInfo AuthConfig Limit
        AllowOverride None
        # Controls who can get stuff from this server.
        Require all granted
    </Directory>
    # DirectoryIndex: sets the file that Apache will serve if a directory
    # is requested.
    <IfModule dir_module>
        DirectoryIndex index.html
    </IfModule>
    # The following lines prevent .htaccess and .htpasswd files from being
    # viewed by Web clients.
    <Files ".ht*">
        Require all denied
    </Files>
    # ErrorLog: The location of the error log file.
    # If you do not specify an ErrorLog directive within a <VirtualHost>
    # container, error messages relating to that virtual host will be
    # logged here.  If you *do* define an error logfile for a <VirtualHost>
    # container, that host's errors will be logged there and not here.
    ErrorLog "logs/error_log"
    # LogLevel: Control the number of messages logged to the error_log.
    # Possible values include: debug, info, notice, warn, error, crit,
    # alert, emerg.
    LogLevel warn
    <IfModule log_config_module>
        # The following directives define some format nicknames for use with
        # a CustomLog directive (see below).
        LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
        LogFormat "%h %l %u %t \"%r\" %>s %b" common
        <IfModule logio_module>
          # You need to enable mod_logio.c to use %I and %O
          LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
        </IfModule>
        # The location and format of the access logfile (Common Logfile Format).
        # If you do not define any access logfiles within a <VirtualHost>
        # container, they will be logged here.  Contrariwise, if you *do*
        # define per-<VirtualHost> access logfiles, transactions will be
        # logged therein and *not* in this file.
        #CustomLog "logs/access_log" common
        # If you prefer a logfile with access, agent, and referer information
        # (Combined Logfile Format) you can use the following directive.
        CustomLog "logs/access_log" combined
    </IfModule>
    <IfModule alias_module>
        # Redirect: Allows you to tell clients about documents that used to
        # exist in your server's namespace, but do not anymore. The client
        # will make a new request for the document at its new location.
        # Example:
        # Redirect permanent /foo http://www.example.com/bar
        # Alias: Maps web paths into filesystem paths and is used to
        # access content that does not live under the DocumentRoot.
        # Example:
        # Alias /webpath /full/filesystem/path
        # If you include a trailing / on /webpath then the server will
        # require it to be present in the URL.  You will also likely
        # need to provide a <Directory> section to allow access to
        # the filesystem path.
        # ScriptAlias: This controls which directories contain server scripts.
        # ScriptAliases are essentially the same as Aliases, except that
        # documents in the target directory are treated as applications and
        # run by the server when requested rather than as documents sent to the
        # client.  The same rules about trailing "/" apply to ScriptAlias
        # directives as to Alias.
        ScriptAlias /cgi-bin/ "/var/www/cgi-bin/"
    </IfModule>
    # "/var/www/cgi-bin" should be changed to whatever your ScriptAliased
    # CGI directory exists, if you have that configured.
    <Directory "/var/www/cgi-bin">
        AllowOverride None
        Options None
        Require all granted
    </Directory>
    <IfModule mime_module>
        # TypesConfig points to the file containing the list of mappings from
        # filename extension to MIME-type.
        TypesConfig /etc/mime.types
        # AddType allows you to add to or override the MIME configuration
        # file specified in TypesConfig for specific file types.
        #AddType application/x-gzip .tgz
        # AddEncoding allows you to have certain browsers uncompress
        # information on the fly. Note: Not all browsers support this.
        #AddEncoding x-compress .Z
        #AddEncoding x-gzip .gz .tgz
        # If the AddEncoding directives above are commented-out, then you
        # probably should define those extensions to indicate media types:
        AddType application/x-compress .Z
        AddType application/x-gzip .gz .tgz
        # AddHandler allows you to map certain file extensions to "handlers":
        # actions unrelated to filetype. These can be either built into the server
        # or added with the Action directive (see below)
        # To use CGI scripts outside of ScriptAliased directories:
        # (You will also need to add "ExecCGI" to the "Options" directive.)
        #AddHandler cgi-script .cgi
        # For type maps (negotiated resources):
        #AddHandler type-map var
        # Filters allow you to process content before it is sent to the client.
        # To parse .shtml files for server-side includes (SSI):
        # (You will also need to add "Includes" to the "Options" directive.)
        AddType text/html .shtml
        AddOutputFilter INCLUDES .shtml
    </IfModule>
    # Specify a default charset for all content served; this enables
    # interpretation of all content as UTF-8 by default.  To use the
    # default browser choice (ISO-8859-1), or to allow the META tags
    # in HTML content to override this choice, comment out this
    # directive:
    AddDefaultCharset UTF-8
    <IfModule mime_magic_module>
        # The mod_mime_magic module allows the server to use various hints from the
        # contents of the file itself to determine its type.  The MIMEMagicFile
        # directive tells the module where the hint definitions are located.
        MIMEMagicFile conf/magic
    </IfModule>
    # Customizable error responses come in three flavors:
    # 1) plain text 2) local redirects 3) external redirects
    # Some examples:
    #ErrorDocument 500 "The server made a boo boo."
    #ErrorDocument 404 /missing.html
    #ErrorDocument 404 "/cgi-bin/missing_handler.pl"
    #ErrorDocument 402 http://www.example.com/subscription_info.html
    # EnableMMAP and EnableSendfile: On systems that support it,
    # memory-mapping or the sendfile syscall may be used to deliver
    # files.  This usually improves server performance, but must
    # be turned off when serving from networked-mounted
    # filesystems or if support for these functions is otherwise
    # broken on your system.
    # Defaults if commented: EnableMMAP On, EnableSendfile Off
    #EnableMMAP off
    EnableSendfile on
    # Supplemental configuration
    # Load config files in the "/etc/httpd/conf.d" directory, if any.
    IncludeOptional conf.d/*.conf
hsmith
Agent Smith
Post by hsmith »
Looks all right.
Output of this command?
grep use_https /usr/local/nagiosxi/html/config.inc.php
Can you check your program URLs?
Admin --> System Config --> System Settings
me.
tigerpeng
Post by tigerpeng »
$cfg['use_https'] = false; // determines whether cron jobs and other scripts will force the use of HTTPS instead of HTTP
(I'd like to have all HTTP requests redirected to HTTPS, should I set this value to true). Is there any instruction of set redirection?
Program URL: http://nagiosxi.connectedcarhub.com/nagiosxi/
hsmith
Agent Smith
Post by hsmith »
tigerpeng wrote: (I'd like to have all HTTP requests redirected to HTTPS, should I set this value to true). Is there any instruction of set redirection?
It needs to be set to true.
Also, in the document you linked, there is a section called "Forcing SSL with a Permanent Redirect".
I think you should read through the document again, it's likely you missed some steps.
me.
tigerpeng
Post by tigerpeng »
I did not go through all the steps :-( - stopped on restart httpd.
Now after went through all the steps, it became worse: http://nagiosxi.connectedcarhub.com/nagiosxi/ return 403. I tried to roll back to HTTP, by restore the original config files but failed (web UI is not accessible). Any instruction on rollback from HTTPS to HTTP?
What is the right command to restart the service?
service nagiosxi restart
service nagios restart
hsmith
Agent Smith
Post by hsmith »
Did you add the forced redirect? Can I see the configuration file you updated?
Restarting:
service httpd restart
me.
tigerpeng
Post by tigerpeng »
    <VirtualHost *:80> # Add this line
    #  SSLRequireSSL
       Options None
       AllowOverride None
       Order allow,deny
       Allow from all
    Redirect permanent / https://nagiosxi.connectedcarhub.com
    #  Order deny,allow
    #  Deny from all
    #   AuthType Basic
    </Directory> # Add this line
    </VirtualHost>
    <VirtualHost *:443>
            SSLEngine on
            AllowOverride All
            </Directory>
    RewriteEngine On
    </IfModule>
    </VirtualHost>
  • /usr/local/nagiosxi/html/config.inc.php
    $cfg['use_https'] = true; // determines whether cron jobs and other scripts will force the use of HTTPS instead of HTTP
hsmith
Agent Smith
Post by hsmith »
You also should change your program URLs inside of XI.
me.
