Host stuck in Pending
daveinvb
Post by daveinvb »
I have added hosts that had the incorrect time period. I have updated the time period, but it is not updating the next check. If I force check a host, it will update it. However I don't want to manually touch hundreds of objects. Is there a way to update them? I've restarted Nagios both through the gui and SSH with no luck.
hsmith
Agent Smith
Re: Host stuck in Pending
Post by hsmith »
Have you looked at the Bulk Modification tool inside of the Core Configuration Manager? This should allow you to change configuration options between hosts.
Former Nagios Employee.
me.
daveinvb
Post by daveinvb »
I'm not changing a configuration option. The next check is a database entry based off of the the time period and the last check. Since these are new entries, there is no last check and only occurs when I forcefully check each one.
EnvBroker1
Post by EnvBroker1 »
I also have hosts that are stuck in Pending. How do you fix that, I didn't get the time period issue.
hsmith
Agent Smith
Post by hsmith »
daveinvb wrote:I'm not changing a configuration option. The next check is a database entry based off of the the time period and the last check. Since these are new entries, there is no last check and only occurs when I forcefully check each one.
I think the easiest way is going to be going to Home > Incident Management > Mass Acknowledge
Change Command Type to Schedule Immediate Check.
Select your hosts/services with an issue there, and submit the command.
me.
daveinvb
Post by daveinvb »
Thanks. That's exactly what I was looking for. I would have never thought to look under Mass Acknowledge. That's resolved my issue and this post can be closed.
Glad to hear this resolved. I'll close this thread out now, but if you need any assistance in the future feel free to open a new one!
hsmith
Agent Smith
Post by hsmith »
It's an extremely useful feature, I'm not 100% sure why we have it under there. I'll ask the devs if maybe the link text should change.
@EnvBroker1 please post a new thread if you have an issue.
me.
