Need to update PHP to version 5.5 or above
In a security sweep, nagios was found to be running version 5.4.16. I need to get this updated to 5.5 or above, however a yum update does not seem to find a newer version. Any advice on how php can be updated, and if there are any conflicts with it?
Re: Need to update PHP to version 5.5 or above
It looks like you can't do it without adding additional repos. I do need to warn you that these versions are untested, and we may not be able to support whatever changes occur by upgrading your php version.
Here is a good explanation: https://www.centos.org/forums/viewtopic ... 48&t=53910
Former Nagios Employee.
me.
me.
