Multistacked Performance Graphs
CFT6Server
Post by CFT6Server »
Anyone experienced issues when stacking a more than usual amount of graphs to one using graph explorer. I am trying to overlay about 10 to 20 CPU utilization onto a stacked graph, and I noticed that previously added items can sometimes just disappear. It takes me a while to find what is missing, and when I try to add it back, sometimes, it won't add back to the graph no matter what.
It would be nice to be able to pick a hostgroup and add ALL the common metrics that I choose at once. As this becomes a painful procedure to ensure that nothing went missing while creating a multistacked graph.
Re: Multistacked Performance Graphs
I tried to replicate this and was unable to. Can you provide a bit more information?
- Do they erase from the Side under Graph Objects?
- Do they erase from under the multistacked graph?
- What browser are you using?
Here's a screenshot for reference -
CFT6Server
I am using Chrome as web browser. They object usually disappears from both the list and the graph. I am building these graphs and almost every time, if I have too many, something will disappear. Now I am adding things that are pretty common, say network send/receive across 10 devices. One item worth mentioning is that the list on the list side is not really sorted and there's no sorting of the labels, which makes it pretty difficult to identify if something is missing or not.....
CFT6Server
I have a live capture of this issue on a SWF video. It is about 2.6MB, what is the best way to send this to you guys to review. In the video, you will clearly see that one of the item previously added was replaced and disappeared.
Awesome, I tried to replicate this with Chrome and couldn't. The video will help out a lot! Are you able to zip it up and PM it over? Otherwise, email it to [email protected].
CFT6Server
rkennedy wrote:Awesome, I tried to replicate this with Chrome and couldn't. The video will help out a lot! Are you able to zip it up and PM it over? Otherwise, email it to [email protected].
The email has been sent. Thanks.
We've received your ticket and will continue via email starting Monday. I'll be closing this thread now.
