Hello.
Sorry in clumsy English.
From the predecessor of took over the Nagios and NagiosQL
Please tell me because I do not know at all.
To change the setting NagiosQL When you click the Do it of Write monitorring data
Can not open / overwrite the configuration file (check the permissions)! It will be displayed.
Perhaps I rights problems but not in trouble in any information retired predecessor is not.
Any file which authority do you may be given to.
By the way, the current authority
/ Usr / local / nagios / etc / hosts the group nagios [501] owner apache [48]
.cfg file under the hosts group is there is a thing of nagios [501] owner root [0] ones and the group of nagios [501] owner (apache [48]).
.cfg file under the hosts are and groups nagios [501] those of the owner root [0]
Group there is a thing of nagios [501] owner (apache [48]).
/ Usr / local / nagios / etc / services is the group nagios [501] owner apache [48]
.cfg file under the services group is there is a thing of nagios [501] owner root [0]
hostgroups.cfg and servicegroups.cfg and hosttemplates.cfg and servicetemplates.cfg the group nagios [501] owner apache [48]
It has become a.
We will let you check please.
Re: Can not open / overwrite the configuration file (check t
What is the result of this command?
ls -l /usr/local/nagios/etc/
ls -l /usr/local/nagios/etc/hosts/
ls -l /usr/local/nagios/etc/services/
Hello.
It sends the result of executing the command .
Please check.
Please check.
Execution result.txt- (68.2 KiB) Downloaded 762 times
I don't think the permissions look right in these two folders -
Can you try to correct the permissions? Judging from your environment, I think they need to be apache:nagios. (this is usually nagios:nagios)
chown -R apache:nagios /usr/local/nagios/etc/hosts/
chown -R apache:nagios /usr/local/nagios/etc/services/
Hello.
It is possible to change the access rights .
However , what it does not break the system by changing the access rights .
Specifications predecessor retired , it is anxious to implement because there are still any information such as the settings .
Please tell me the risks and workarounds so good in the
Without taking a look at your system, and seeing exactly how things are setup - I cannot make a decision regarding this. It does seem that your system is modified.
With our standard Nagios Core install, this is how things operate though for permissions.
Hello.
Message of change the access rights of the pointed out gotten place (Can not open / overwrite the configuration file (check t...) has confirmed that it will not be displayed .
Thank you for your response.
Thanks for that update, does that mean this issue is resolved?
Hello.
Okay.
Which means that this problem is resolved .
Okay.
