Something went wrong with commad submitted to Nagios Core
thur686
Post by thur686 »
Host OS: CentOS6
Nagios XI version: 5.2.2
When we try to use the scheduled downtime feature (downtime.php) we encounter the following error message:
Something went wrong with the commad submitted to Nagios Core
A quick internet search turned up this thread: https://support.nagios.com/forum/viewto ... 16&t=35033
Rather than use that work-around, I thought it would be better to just fix the certificate problem. It turns out that was a bad idea as I have no idea how to fix a certificate problem. These are the commands I tried:
yum install ca-certificates
update-ca-trust force-enable
cd /etc/pki/tls/certs/
cp ca.crt /etc/pki/ca-trust/source/anchors/
update-ca-trust extract
service nagios restart
service httpd restart
I tried to import our CA certificate (ca.crt) into "/etc/pki/tls/certs/ca-bundle.crt" unsuccessfully. Curl validates the problem.
curl https://devnagios.mydomain.com/nagiosxi/
curl: (35) SSL connect error
curl https://devnagios.mydomain.com/nagiosxi/ -o /etc/pki/tls/certs/ca-bundle.crt
Re: Something went wrong with commad submitted to Nagios Cor
The work around that @ssax posted should work, but I also believe that this was fixed in 5.2.3.
Is using the patch, or upgrading an option?
thur686
Post by thur686 »
Thanks rkennedy, I can use the work around. However the Network Status map (status.php) doesn't work either and I was thinking that the root cause could also be a local certificate problem.
We did not have plans to move to 5.2.3 yet.
I can try the downtime.zip work around and open another thread for the Network Status map if that is best.
Yes, you can do that - start a new thread for the Network Status map issue. Show us a screenshot of the error that you see in the web UI, and a tail of the apache error log in code wraps.
tail -100 /var/log/httpd/error_log
thur686
Post by thur686 »
[Tue Feb 09 14:38:42 2016] [error] [client 10.10.10.10] PHP Notice:  Trying to get property of non-object in /usr/local/nagiosxi/html/includes/components/xicore/downtime.php on line 501, referer: https://securenagios.com/nagiosxi/includes/components/xicore/downtime.php
[Tue Feb 09 14:38:42 2016] [error] [client 10.10.10.10] PHP Warning:  Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/xicore/downtime.php on line 501, referer: https://securenagios.com/nagiosxi/includes/components/xicore/downtime.php
If the supplied zip did not work, then an upgrade will be necessary to resolve. We don't generally back-port fixes.
thur686
Post by thur686 »
I performed an upgrade to 5.2.5 and it did not help. Although the error message has changed to 'Something went wrong with the command submitted to Nagios Core' and the color around the message is RED rather than green.
I will open a support ticket, thanks for the assistance.
Haven't seen a ticket come in yet, just checking in. Did you get a bounceback, or just haven't emailed in yet?
Update: We got the ticket, so I will be closing this thread now.
