We have email alert about search result and there is a link to in email
e.g.
The alert was processed with the following thresholds:
Lookback period: 24h
Warning: 2
Critical: 1
Here is the full alert output:
CRITICAL: 28 matching entries found |logs=28;2;1
See the last 24h in the Nagios Log Server dashboard.
Nagios Log Server
the link is https://nagios-log-server/nagioslogserv ... T06:46:57Z
however, when i click the link, it said cannot find the link but i can view the result in nagios log server.
Dashboard Link
Re: Dashboard Link
That dashboard link looks fine. My bet is that you have either made some change to the dashboard after the alert was set up, or you are running an older version of Nagios Log Server.
Have you made any notable changes to the dasboard in question?
What version of NLS are you running?
pccwglobalit
Re: Dashboard Link
hi jolson,
i found the problem is due to ssl problem. After i upgrade to 1.4, our https is not working. i have tried using reverse proxy and same thing happened. i can see login page but when i input username and password, it said bad gateway.
previous version 2015R2.1 is no problem on https.
Regards,
Lam
Regards,
Lam
Re: Dashboard Link
There are some changes that need to be made now to make it work on the newest version of NLS. Check this out: https://assets.nagios.com/downloads/nag ... Server.pdf
Former Nagios Employee.
me.
me.
