NRPE issue - Plz refer https://support.nagios.com/forum/view
Sundar
Post by Sundar »
I was referring to - https://support.nagios.com/forum/viewto ... f=7&t=9777 for a similar issue that we have. Especially the portion of the response that says "In 0.4.x, the NRPE handlers section was absorbed into the "External Scripts" section. Do you have the section "[/settings/external scripts/scripts]" in your ini?"
I don't see "[/settings/external scripts/scripts]" either in "nsclient.ini"...
But, I see that post has been locked out to understand what was the work around provided and how to fix "Failed to parse arguments for command ...." error
Please advise on how to fix this error. Thanks
Regards,
hsmith
Agent Smith
Re: NRPE issue - Plz refer https://support.nagios.com/forum/
Post by hsmith »
Can you please explain what your issue is? If you're missing that section, you can just write it in.
Take a look at this: http://docs.nsclient.org/howto/external_scripts.html http://docs.nsclient.org/tutorial/core/index.html
Former Nagios Employee.
me.
