I SSH backups to a remote server daily from my Nagios server. I have the backup limit on the ssh page set to 7 but the server does not cleanup the old files causing the remote server disk to fill. The SSH user is able to send file and delete files on the remote server with no issues.
[caecd@localhost nagiosbackup]$ ls
ssh_test_secure_copy.txt
[caecd@localhost nagiosbackup]$ rm ssh_test_secure_copy.txt
The backup logs seems to be OK:
03-03-2016 00:00:01 DEBUG: Running scheduled local backup ...
03-03-2016 00:00:01 INFO: Creating a local backup: nagiosxi.1456984801
03-03-2016 00:00:01 INFO: Too many backups! Limit is 7. Removing: nagiosxi.1428728401.tar.gz before proceeding with backup.
03-03-2016 00:00:03 DEBUG: Sending create local backup command to CmdSubsystem
03-03-2016 03:00:01 DEBUG: Running scheduled SSH backup ...
03-03-2016 03:00:01 DEBUG: Sending create local backup command to CmdSubsystem
The nagiosxi.1428728401.tar.gz file above was not removed from the remote server.
I am running 2.7 on CentOS6
Backup limit not honored for SSH backups
Re: Backup limit not honored for SSH backups
Are you on 2014R2.7 or 2012R2.7? This should have been fixed in 2014R2.1. Let us know your full version and we can test this out.
I am on 2014R2.7
I tested this on Nagios XI 5.2.5 and "Scheduled Backups" component ver. 1.1.2. It worked as expected. I setup my "Backup Limit" to "2", and I have only two backups on the remote server.
In my case, the backup limit was honored.
Remove all of the backups but let's say one or two. Watch the backup directory on the remote box to see if the backup number will exceed 7. If it does, try upgrading to the latest release of XI to see if this is going to fix the issue.
root@debian:/home/lmiltchev/backups# ls -la
total 300036
drwxrwxrwx 2 lmiltchev lmiltchev 4096 Mar 3 13:54 .
drwxr-xr-x 3 lmiltchev lmiltchev 4096 Mar 29 2015 ..
-rw-r--r-- 1 lmiltchev lmiltchev 153447159 Mar 3 13:47 nagiosxi.1457034422.tar.gz
-rw-r--r-- 1 lmiltchev lmiltchev 153463286 Mar 3 13:54 nagiosxi.1457034842.tar.gz
-rw-r--r-- 1 lmiltchev lmiltchev 110 Mar 3 13:03 ssh_test_secure_copy.txtRemove all of the backups but let's say one or two. Watch the backup directory on the remote box to see if the backup number will exceed 7. If it does, try upgrading to the latest release of XI to see if this is going to fix the issue.
Also - does the remote SSH user have permission to delete files? One thing to check on top of what @lmiltchev mentioned.
Upgrading is really not an option at the moment. Is there anything I can do to troubleshoot the existing install? @rkennedy see my original post on ssh permission. It is tested and working.
Do you have only the "SSH" scheduled backup set up in XI or you also have the "FTP" and/or "Local" backups set up? What are the "Backup Limit" values on all of them?
How many backups do you have on the remote server at the moment? Can you run the following commands on the remote box?
ls -lad /path/to/the/backup/directory
ls -la /path/to/the/backup/directoryBe sure to check out our Knowledgebase for helpful articles and solutions!
FTP Backups: Disabled
SSH Backups: Enabled - Next Run: Fri, Mar 4th at 3:00 AM -06:00 CST
Local Backups: Enabled - Next Run: Fri, Mar 4th at 12:00 AM -06:00 CST
Last Backup Size: 360.41 MB
[root@localhost nagiosbackup]# ls
[root@localhost nagiosbackup]# ls -lad
drwxrwxr-x 2 bexar bexar 8192 Mar 3 06:47 .
total 16
drwx------ 3 bexar bexar 4096 Oct 18 2014 ..
-rw-r--r-- 1 bexar bexar 110 Mar 3 06:47 ssh_test_secure_copy.txt
There is only one file as there were about 50 zero byte files that I deleted. I have gone through this exercise several times already so I know it will not delete the backups.
total 16
What is the "Scheduled Backups" component version that you see under the "Manage Components" page?
Admin->Manage Components
Do you see a new version available for download when you click on "Check for Updates"?
