Load MIBs to log server
robjohn
Post by robjohn »
I'd like to know how to load mibs to log server. We have two clustered servers.
hsmith
Agent Smith
Re: Load MIBs to log server
Post by hsmith »
What are you trying to load MIBs to Logserver for?
Former Nagios Employee.
me.
Envera IT
Post by Envera IT »
If you're trying to import mibs for the snmptrap input you need to convert the mib's to YAML.
https://discuss.elastic.co/t/mib-oid-translation/29710
The import script lives in
/usr/local/nagioslogserver/logstash/vendor/jruby/lib/ruby/1.9/dl/import.rb
I tried running this on a directory of mibs in /tmp/mibs/ but it failed : (
/usr/local/nagioslogserver/logstash/vendor/jruby/lib/ruby/1.9/dl/import.rb: line 1: require: command not found
/usr/local/nagioslogserver/logstash/vendor/jruby/lib/ruby/1.9/dl/import.rb: line 2: require: command not found
/usr/local/nagioslogserver/logstash/vendor/jruby/lib/ruby/1.9/dl/import.rb: line 3: require: command not found
/usr/local/nagioslogserver/logstash/vendor/jruby/lib/ruby/1.9/dl/import.rb: line 4: require: command not found
/usr/local/nagioslogserver/logstash/vendor/jruby/lib/ruby/1.9/dl/import.rb: line 6: module: command not found
/usr/local/nagioslogserver/logstash/vendor/jruby/lib/ruby/1.9/dl/import.rb: line 7: class: command not found
/usr/local/nagioslogserver/logstash/vendor/jruby/lib/ruby/1.9/dl/import.rb: line 8: syntax error near unexpected token `('
/usr/local/nagioslogserver/logstash/vendor/jruby/lib/ruby/1.9/dl/import.rb: line 8: `    def initialize(handlers)'
Hopefully the Nagios guys can point us in the right direction.
I like graphs...
jolson
Attack Rabbit
Post by jolson »
I believe I got this working using the following procedure:
yum install libsmi libsmi-devel -y
gem install snmp
gem install dl
wget https://raw.githubusercontent.com/hallidave/ruby-snmp/master/import.rb
mkdir mibs
(move your mibs into the mibs folder)
ruby import.rb mibs/
cd data/ruby/snmp/mibs/
ls -ltr
Note that your mibs have been imported, you can verify this with the output of ls -ltr:
-rwxrwxr-x. 1 nagios nagios   728 Jan 18 16:20 CIRCUIT-IF-MIB.yaml
-rwxrwxr-x. 1 nagios nagios   742 Jan 18 16:20 ATM-TC-MIB.yaml
-rwxrwxr-x. 1 nagios nagios  5135 Mar 18 08:16 DS1-MIB.yaml
Note that there is a file datestamped with March 18th, meaning that the YAML file was created today. Success!
Twits Blog
