schedule downtime issue - jstoddart
We are seeing the same on our Nagios XI 5.2.5, is there any progress on this?
Moderator Note: This topic was split from: https://support.nagios.com/forum/viewto ... 30#p175941
Re: schedule downtime issue - jstoddart
Ok, now we're getting somewhere: "Start or end time not valid"
jstoddart, can you replicate that same trace and see if you are seeing the same thing?
What is the output of these commands:
date
localeRe: schedule downtime issue - jstoddart
Tried the trace and just get "Start time or end time Invalid" when I try now and no trace file, have reverted the changes and still the same
Can you please run the date and locale commands and post their output?
CentOS release 6.3 (Final)
[NagiosX1:main.linux64 ~]# date
Fri Mar 18 07:39:15 GMT 2016
[NagiosX1:main.linux64 ~]# locale
LANG=en_US.UTF-8
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_ALL=
LANG=en_US.UTF-8
LC_ALL=
Please edit the file again and add this additional code after the code you added for the first trace:
Then schedule downtime again and attach a sanitized copy of your /tmp/downtime_args.txt.
Thank you
ob_start();
var_dump($args);
$cresult = ob_get_clean();
$cfile = '/tmp/downtime_args.txt';
file_put_contents($cfile, $cresult);Thank you
Just tried that but no file being produced in /tmp, will investigate further
Are there any errors in /var/log/httpd/error_log about that log file? You might need to create it manually and give it appropriate permissions:
touch /tmp/downtime_args.txt
chmod 777 /tmp/downtime_args.txtFormer Nagios employee
Apologies for delay on getting back to this, we have just upgraded to 5.2.7 and this seems to all be Ok now.
Jamie
Jamie
Great to hear. I'll be closing this thread now, but feel free to open another if you need anything in the future!
