automatic report generation
asardouk
Post by asardouk »
I want to know if there is a way to generate reports for every host with specific service graphs automatically by creating config file somewhere ?
I want also to know if there a way to use my bandwidth scripts to generate bandwidth usage report ? is there a special format to get it to work ?
My script check routers via snmp and send perfdata in this format :
inUsage=66.08%;85;95;0;100 outUsage=35.70%;85;95;0;100 inBandwidth=132.162696Mb/s;170.00;190.00;0;200.00 outBandwidth=71.404228Mb/s;170.00;190.00;0;200.00
Nagios XI 5.2.5 - CentOS Linux release 7.2.1511
Re: automatic report generation
Are you looking for the reports to be emailed?
if so there isn't an automated mechanism. However most of the reports built into Nagios XI are built on the fly and can be passed arguments to specify the host you want.
What specific report are you looking for, maybe we can show how the URL for the report can be built
asardouk
Post by asardouk »
With availability report, i can generate report for a hostgroup A and to display all service performance graphs.
How can i generate the same report with specific service graph ?
my second question is about the Bandwidth Usage report. how can i adapt my script so it can generate correct data to build this kind of report ?
Are you looking to create an Availability report with only one service on it?
If so, create a service group with only one service in it and run the report using only that group, also check this box (Display service performance graphs) on the report to get the graph to be displayed in the report.
Take a look at this link for the plugin guidelines. It describes how the performance data needs to be formatted.
https://nagios-plugins.org/doc/guidelines.html#AEN200
asardouk
Post by asardouk »
tgriep wrote:Are you looking to create an Availability report with only one service on it?
Well, I have per example "Service A" that i use for "Hostgroup A". I don't have a service for every host. So i cannot create a service group with this service. My goal is to generate a report for "hostgroup A" with specific services ( not all).
For the performance data please check my first message. I think that my script send the right format. I need to know how to make "Bandwidth Usage report" create report for my bandwidth service ?
There isn't a way to select a hostgroup for the Availability report and only show some of the services. It will show all of the services when it is ran.
For the performance data graph, can you go in to Service Details for that check, click on the Advanced Tab, screen capture it and post it here.
Is that check generating a performance data graph at all?
asardouk
Post by asardouk »
I have graph for my service. check pictures bellow :
I used nagios xi Configuration Wizard: Network Switch / Router and it allows to generate this kind of report :
How can i do the same with my script ?
bwallace
Post by bwallace »
Sorry, but running a custom report based on a custom plugin is not possible/supported.
asardouk
Post by asardouk »
Thanks.
bwallace
Post by bwallace »
Sure, were there any other questions, or may we close this thread?
