Email Alerts not sending
m1kew1lson
Post by m1kew1lson »
I am working with a new Nagios Core 3.3.1 setup on freebsd 8.2. I am using sendmail for email alerts. I can send emails from a command line however when nagios fires an alert I never get the emails sent. I see this when I tail the maillog. I see the config for the contacts correct. Has anyone seen this before? I am guessing the to=$ is where the unknown user is coming from
Oct 11 10:40:34 gmt-nag01 sendmail[67348]: p9BEeYfO067348: from=nagios, size=220, class=0, nrcpts=1, msgid=<[email protected]>, relay=nagios@localhost
Oct 11 10:40:34 gmt-nag01 sm-mta[67349]: p9BEeYSS067349: <[email protected]>... User unknown
Oct 11 10:40:34 gmt-nag01 sendmail[67348]: p9BEeYfO067348: to=$, ctladdr=nagios (181/181), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30220, relay=[127.0.0.1] [127.0.0.1], dsn=5.1.1, stat=User unknown
Oct 11 10:40:34 gmt-nag01 sm-mta[67349]: p9BEeYSS067349: from=<[email protected]>, size=220, class=0, nrcpts=0, proto=ESMTP, daemon=Daemon0, relay=localhost [127.0.0.1]
jsmurphy
Re: Email Alerts not sending
Post by jsmurphy »
Are you able to post your send email command definition from nagios as well?
