Check Number Files in a directory
Hi everybody,
Firstly, sorry for my english but i'm a french user ...
I hope this is the good emplacement to write my problem :
I just installed Nagios 4.1.1 on a debian 8 Jessie. I don't really use Linux daily, and I need to migrate "nagios on our windows server to this nagios server.
I delete the old nsclient++ on windows server and install the latest 0.4.4.19
The installation and configuration are OK, but i'm blocked about monitoring "Check number files in a directory".
Indeed, I want to supervise a directory and count file on this directory in a windows server.
On nagios (debian), in command.cfg i' wrote :
command_name CheckNumberFiles
command_line $USER1$/check_nrpe §H $HOSTADDRESS$ §c $ARG1$ §a $ARG2$
In windows.cfg :
host_name name of my windows server
service_description Number of files on directory XXX
check_commande CheckNumberFiles!check_files!/path:C:\\DIRECTORY\\OTHER DIRECTORY" /searchdepth:1 /selage:ignore /warning:5 /critical:10
On my web interface, i've an error concerning this service :
Number of files on Request
UNKNOWN 08-04-2016 13:44:06 0d 2h 2m 18s 3/3 Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option).
So I think my problem is on my windows server.
I suppose check_nrpe is OK because i use it with another service and it's OK (checkMEM).
But maybe the script check_files or the nsclient.ini is not ok... ?
Anyone help me please ?
Best Regards,
In windows.cfg :
Best Regards,
Re: Check Number Files in a directory
Take a look at your nsclient.ini, and look for the [/settings/NRPE/server] section. under it, add or modify these two variables -
They may already exist in your config, and if they do just change the 0's to 1's. Then, restart the NSClient++ service, and the check should be working. If not, please post your NSClient++ configuration for us to look at.
; COMMAND ALLOW NASTY META CHARS - This option determines whether or not the we will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow nasty characters = 1
; COMMAND ARGUMENT PROCESSING - This option determines whether or not the we will allow clients to specify arguments to commands that are executed.
allow arguments = 1
Thanks a lot for fast reply !!!
Indeed, I'd add (or verify) this lines in nsclient.ini on all windows server. Moreover, they are at 1.
So, i copy the content of this file :
EDIT : i check once again your reply and i notice that i wrote "allow_nasty_meta_chars = 1" or you tell me that it's "allow_nasty_chars = 1".
Maybe this is that ?
# If you want to fill this file with all avalible options run the following command:
# nscp settings --generate --add-defaults --load-all
# nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/settings/default]
; Undocumented key
password = mypassword XXX
; Undocumented key
allowed hosts = nagios-debian
port=5666
allow_arguments = 1
; Undocumented key
verify mode = none
; Undocumented key
insecure = true
[/settings/external scripts]
allow arguments = 1
[/modules]
NRPEListener.dll #I've add ths lines recently to test if it's better because in older server "nagios" on windows i saw this lines on nsc.ini ... but it doesn't work.
NSClientListener.dll
CheckWMI.dll
FileLogger.dll
CheckSystem.dll
CheckDisk.dll
CheckEventLog.dll
CheckHelpers.dll
CheckSystem.dll
SysTray.dll
CheckWMI.dll
CheckNSCP.dll
CheckExternalScripts.dll
NRPEClient.dll
CheckTaskSched.dll
; Undocumented key
CheckExternalScripts = 1
; Undocumented key
CheckHelpers = 1
; Undocumented key
CheckEventLog = 1
; Undocumented key
CheckNSCP = 1
; Undocumented key
CheckDisk = 1
; Undocumented key
CheckSystem = 1
; Undocumented key
NSClientServer = 1
; Undocumented key
NRPEServer = 1
[crash]
; Archive crash dump files if a crash is detected
;archive=1
; Submit crash reports to a crash report server (this overrrides archive)
;submit=0
; Restart service if a crash is detected
restart=1
Reason: Please use [code][/code] tags around long output
I am running NSClient++ v. 0.4.4.15, and in the nsclient.ini file I have:
According to the NSClient++ "stable (0.4.4)" documentation, the correct syntax is
http://docs.nsclient.org/0.4.4/faq/index.html
You can use "true" or "1" - both should work, but I don't think underscores ("allow_nasty_meta_chars") will work with this version of NSClient++.
allow nasty characters = true
Thanks, I'll try tomorrow and tell you if it's working.
Good evening,
Good evening,
I've modified the following lines and it's better :
But still not working => Invalid command line: unrecognised option '/path:C:GESTIONREQUEST'
So I saw again the example of nsclient into check_files.vbs :
check_command check_nrpe_external!check_files!/path:"d:\\journal" /searchdepth:1 /selage:ignore /warning:30 /critical:40
' give alarm if there are more than 30 files under d:\journal
And in mi windows.cfg :
check_command check_nrpe!check_files!/path:"C:\\GESTION\\REQUEST\\" /searchdepth:1 /selage:ignore /warning:5 /critical:10
Thanks by advance.
Thanks by advance.
Can you try the check from the command line instead of in XI? Post the output of running it here.
Former Nagios Employee.
me.
me.
I need to install the demo of Nagios XI in another VM in order to try the command, it's exact ?
Do you have terminal access to your current Nagios XI server?
me.
me.
