Hi guys,
I'm new to Nagios and have been searching for most of the day with limited luck.
Can anyone advise if there is a script or Wizard available to monitor Outlook 365? Essentially I would like something to send an email to an alias and then to monitor the inbox to see that email is received. If email received no further action required but if not I would like to generate an alert at that point.
Any help would be greatly appreciated.
Dave
Outlook 365
Re: Outlook 365
Look into 'check_email_delivery' to see if it work for you - I'm not very familiar with the inner workings of Outlook 365. This plugin is installed by default on Nagios XI, you'll find it in /usr/local/nagios/libexec. It sounds like it does exactly what you're looking for, here is some documentation on it:
https://exchange.nagios.org/directory/P ... ry/details
-hopefully this helps, let us know, thanks -
