Disabling service checks when host is down
arnab.roy
Post by arnab.roy »
Hi All,
I would like nagios to stop polling and running service checks against a host which is down, as it is pointless and a waste of resources. Can you suggest how I might be able to achieve this.
Cheers
Arnab
mguthrie
Re: Disabling service checks when host is down
Post by mguthrie »
You'd probably have to define a custom event handler to do this, and send a core command directly to the nagios.cmd pipe.
http://nagios.sourceforge.net/docs/nagi ... dlers.html
The accepted command pipe names and usage guidelines can be found here.
http://old.nagios.org/developerinfo/ext ... ndlist.php
