Cant montior 32 bit counter
devabab
Post by devabab »
Hi Team,
I have a 32 bit process running on windows machine but I cant monitor using the CheckCounter.
The process looks like below.
Install.New.Service (32 bit)
nagios says CRIT: Counter not found.
But with other process like winlogon it is working. The process looks like winlogon.exe
I only use winlogon and the check detects the process.
Could you please help?
Regards,
Dev
Re: Cant montior 32 bit counter
Can you show us the full check_command that your service is using?
Have you taken a look at your performance counters to see if it actually exists? This article will help you. https://support.nagios.com/kb/article.p ... ategory=19
