CPU Load - 5m 15m missing in graphs
CFT6Server
Post by CFT6Server »
I have a service check that checks for CPULoad for a linux machine. The performance data has the proper results of 1m, 5m, 15m. However the graphs only shows 1m. Please advise.
jomann
Development Lead
Re: CPU Load - 5m 15m missing in graphs
Post by jomann »
What check are you running? The performance data looks off... there should be ; at the end of each line, like so:
time=0.217354s;;;0.000000 size=557B;;;0
As per the plugin guidelines here: https://assets.nagios.com/downloads/nag ... inapi.html
CFT6Server
We are using check_linux_cpuload.pl
As @jomann mentioned, your plugin doesn't look to be following the plugin requirements. https://nagios-plugins.org/doc/guidelin ... PLUGOUTPUT
Here's how your plugin is outputting -
  # Build performance data line
  $perfdata=sprintf("Load1m=%.2f Load5m=%.2f Load15m=%.2f",$Load1min,$Load5min,$Load15min);
The guidelines -
    space separated list of label/value pairs
    label can contain any characters except the equals sign or single quote (')
    the single quotes for the label are optional. Required if spaces are in the label
    label length is arbitrary, but ideally the first 19 characters are unique (due to a limitation in RRD). Be aware of a limitation in the amount of data that NRPE returns to Nagios
    to specify a quote character, use two single quotes
    warn, crit, min or max may be null (for example, if the threshold is not defined or min and max do not apply). Trailing unfilled semicolons can be dropped
    min and max are not required if UOM=%
    value, min and max in class [-0-9.]. Must all be the same UOM. value may be a literal "U" instead, this would indicate that the actual value couldn't be determined
    warn and crit are in the range format (see the Section called Threshold and ranges). Must be the same UOM
    UOM (unit of measurement) is one of:
        no unit specified - assume a number (int or float) of things (eg, users, processes, load averages)
        s - seconds (also us, ms)
        % - percentage
        B - bytes (also KB, MB, TB)
        c - a continous counter (such as bytes transmitted on an interface)
For the record, linking to your past thread regarding this. It may be worth looking into what @Box293 mentioned in our last response, as that will provide a bit of debugging. https://support.nagios.com/forum/viewto ... 99#p163891
CFT6Server
i have this running on quiet a few servers and only this check is showing this. Other checks are showing up fine on the graphs?
If the performance data for that check was changed in the past to a different label, number of labels, etc.. that could cause the graph to not show all of the performance data.
If you go to this folder
/usr/local/nagios/share/perfdata/kdcnaggm01
and delete the xml and rrd files for that check, they should get recreated with all of the performance data values.
FYI, this will take around 20 minutes to repopulate the graph.
ssax
Dreams In Code
Post by ssax »
It should work (works on mine too), please run this command on the broken one and post the output:
- Make sure to change HOSTNAME and SERVICENAME
rrdtool info /usr/local/nagios/share/perfdata/HOSTNAME/SERVICENAME.rrd
Thank you
