nagios db fluch and vacuum script help needed
benhank
Post by benhank »
In my relentless pursuit of nagiosisness, I came across this article from waaaaayyyy back:
http://labs.nagios.com/2011/11/15/nagios-xi-benchmarking-experiments/
I am interested in making a script that does maintenance on my dbs. But when I run the commands :
psql nagiosxi nagiosxi -c "vacuum;"
psql nagiosxi nagiosxi -c "vacuum analyze;"
psql nagiosxi nagiosxi -c "vacuum full;"
i get:
WARNING:  skipping "pg_authid" --- only superuser can vacuum it
WARNING:  skipping "pg_database" --- only superuser can vacuum it
WARNING:  skipping "pg_tablespace" --- only superuser can vacuum it
WARNING:  skipping "pg_pltemplate" --- only superuser can vacuum it
WARNING:  skipping "pg_shdepend" --- only superuser can vacuum it
WARNING:  skipping "pg_shdescription" --- only superuser can vacuum it
WARNING:  skipping "pg_auth_members" --- only superuser can vacuum it
VACUUM
[root@LKENNAGIOST01 ~]# psql nagiosxi nagiosxi -c "vacuum analyze;"
VACUUM
[root@LKENNAGIOST01 ~]# psql nagiosxi nagiosxi -c "vacuum full;"
VACUUM
this is on xi5 latest versions with postgress dbs. Any ideas on what I need to do to make it work?
thanks in advance!
Proudly running:
Nagios Network Analyser
Nagios Fusion
ssax
Dreams In Code
Re: nagios db fluch and vacuum script help needed
Post by ssax »
This should work for you:
psql nagiosxi postgres -c "vacuum;"
psql nagiosxi postgres -c "vacuum analyze;"
psql nagiosxi postgres -c "vacuum full;"
Let us know the results.
Thank you
benhank
Post by benhank »
worked beautifully thanks man!
how do i force it to flush and vacuum mysql?
Proudly running:
Nagios Fusion
ssax
Dreams In Code
Post by ssax »
These should be handled automatically already by the settings in Admin > Performance Settings > Databases, they are the three optimize intervals.
benhank
Post by benhank »
thanks man lock it up!
Proudly running:
Nagios Fusion
