check_cluster
natalia.fitsyk
check_cluster
Post by natalia.fitsyk »
Hi everyone,
I have a problem with my custom plugin, I need to check the cluster so I implement the .sh in the remote machine.
On my Nagios Server the config are:
more /usr/local/nagios/etc/objects/commands.cfg
# 'check_cluster' command definition
command_name check_nrpe_cluster
command_line /usr/local/nagios/libexec/check_nrpe -H $HOSTADDRESS$ -c check_nrpe_cluster
more /usr/local/nagios/etc/objects/service.cfg
host_name remote_machine
service_description check cluster
check_command check_nrpe!check_nrpe_cluster!1!
more /usr/local/nagios/etc/hosts/remote_machine.cfg
define host {
alias remote_machine
display_name cluster
address x.x.x.x
use
check_command check_nrpe_cluster!
use generic-host
when I execute the check_nrpe on server Nagios I have this output:
[root@server_nagios~]# /usr/local/nagios/libexec/check_nrpe -H x.x.x.x -c check_nrpe_cluster
CRITICAL:service_name disabled;:RGMANAGER:RUNNING;
(in this moment the service_name in disabled on my cluster for this test)
The output is same on the local machine:
[root@remote_machine ~]# /usr/local/nagios/libexec/check_nrpe -2 -H localhost -c check_nrpe_cluster
command[check_nrpe_cluster]=/usr/local/nagios/libexec/check_rhcs.sh -c 1
But the mail alert don't arrived.
What is wrong?
Thank for the help.
check_rhcs_simple.sh.txt
(1.67 KiB) Downloaded 274 times
Re: check_cluster
Closing this out as it's a duplicate post, we will continue in your intiial thread.
https://support.nagios.com/forum/viewto ... 94#p195094
