# $Id: check_log2.pl,v 1.2 2005/12/16 18:41:45 harpermann Exp $
# Log file regular expression detector for Nagios.
# Written by Aaron Bostick (
[email protected])
# Last modified: 05-02-2002
# Thanks and acknowledgements to Ethan Galstad for Nagios and the check_log
# plugin this is modeled after.
# Usage: check_log2 -F <log_file> -O <seek_file> -q <pattern> [-e <negpattern>]
This what you're looking for?
Examples:
# Check for login failures in the syslog...
# check_log -F /var/log/messages -O /usr/local/nagios/var/check_log.badlogins.old -Q "LOGIN FAILURE"
# Check for port scan alerts generated by Psionic's PortSentry software...
# check_log -F /var/log/messages -O /usr/local/nagios/var/check_log.portscan.old -Q "attackalert"
# Paths to commands used in this script. These
# may have to be modified to match your system setup.
PATH="/usr/bin:/usr/sbin:/bin:/sbin"
PROGNAME=`basename $0`
PROGPATH=`echo $0 | sed -e 's,[\\/][^\\/][^\\/]*$,,'`
#. $PROGPATH/utils.sh
. /usr/local/nagios/libexec/utils.sh
print_usage() {
echo "Usage: $PROGNAME -F logfile -O oldlog -Q query"
echo "Usage: $PROGNAME --help"
print_help() {
echo ""
print_usage
echo ""
echo "Log file pattern detector plugin for Nagios"
echo ""
support
# Make sure the correct number of command line
# arguments have been supplied
if [ $# -lt 6 ]; then
print_usage
exit $STATE_UNKNOWN
fi
# Grab the command line arguments
exitstatus=$STATE_WARNING #default
while test -n "$1"; do
case "$1" in
--help)
print_help
exit $STATE_OK
-h)
print_help
exit $STATE_OK
-F)
logfile=$2
shift
-O)
oldlog=$2
shift
-Q)
query=$2
shift
echo "Unknown argument: $1"
print_usage
exit $STATE_UNKNOWN
esac
shift
done
# If the source log file doesn't exist, exit
if [ ! -e $logfile ]; then
echo "Log check error: Log file $logfile does not exist!"
exit $STATE_UNKNOWN
echo $STATE_UNKNOWN > $oldlog.STATE
fi
# If the oldlog file doesn't exist, this must be the first time
# we're running this test, so copy the original log file over to
# the old diff file and exit
if [ ! -e $oldlog ]; then
cat $logfile > $oldlog
if [ `tail -1 $logfile | grep -i $query | wc -l` -gt 0 ]
then
echo "Log check data initialized... Last line contained error message."
echo $STATE_CRITICAL > $oldlog.STATE
exit $STATE_CRITICAL
else
echo "Log check data initialized..."
echo $STATE_OK > $oldlog.STATE
exit $STATE_OK
fi
fi
# A bug which was caught very late:
# If newlog is shorter than oldlog, the diff used below will return
# false positives for the query because the will be in $oldlog. Why?
# Because $oldlog is not rolled over / rotated, like $newlog. I need
# to fix this in a kludgy way.
if [ `wc -l $logfile|awk '{print $1}'` -lt `wc -l $oldlog|awk '{print $1}'` ]
then
rm $oldlog
then
echo "Log check data re-initialized... Last line contained error message."
else
echo "Log check data re-initialized..."
exit $STATE_OK
fi
fi
# Everything seems fine, so compare it to the original log now
# The temporary file that the script should use while
# processing the log file.
if [ -x mktemp ]; then
tempdiff=`mktemp /tmp/check_log.XXXXXXXXXX`
else
tempdate=`/bin/date '+%H%M%S'`
tempdiff="/tmp/check_log.${tempdate}"
touch $tempdiff
fi
diff $logfile $oldlog > $tempdiff
if [ `wc -l $tempdiff|awk '{print $1}'` -eq 0 ]
then
rm $tempdiff
touch $oldlog.STATE
exitstatus=`cat $oldlog.STATE`
echo "LOG FILE - No status change detected. Status = $exitstatus"
exit $exitstatus
fi
# Count the number of matching log entries we have
count=`grep -c "$query" $tempdiff`
# Get the last matching entry in the diff file
lastentry=`grep "$query" $tempdiff | tail -1`
rm -f $tempdiff
if [ "$count" = "0" ]
then
echo "Log check ok - 0 pattern matches found"
exitstatus=$STATE_OK
else
echo "Log check NOK - $lastentry"
exitstatus=$STATE_CRITICAL
fi
exit $exitstatus
