check_snmp issue
bmccarthy
check_snmp issue
Post by bmccarthy »
I am having an issue I can't seem to solve using check_snmp v1.4.16
Using it without the -w warning or -c critical issues, it returns data as expected:
# ./check_snmp -H 192.168.0.214 -P 2c -c public -m /usr/share/snmp/mibs/MyMIB.txt -o DIFFPRES -l DIFFPRES
SNMP OK - DIFFPRES  10.56 psi  | DIFFPRES= 10.56
Notice the "psi" unit in the output above.
If I add the -w and - c I get:
# ./check_snmp -H 192.168.0.214 -P 2c -c public -m /usr/share/snmp/mibs/MyMIB.txt -o DIFFPRES -l DIFFPRES -w 18 -c 20
SNMP OK - DIFFPRES 10.69 | DIFFPRES=10.69
Notice there is no "psi" this time.
I verified that the device is returning the "psi" with an snmpget:
# snmpget -v 2c -c public -m /usr/share/snmp/mibs/MyMIB.txt 192.168.0.214 DIFFPRES
Sbtfp3::DIFFPRES = STRING:  10.9 psi
Has anyone experienced this behavior from check_snmp. If so, I cannot find it in this forum nor with Google. I've tried just about everything I can think of with options/switches so I'm seeking new input.
Thanks in advance for your time.
Reason: marking with green check mark
Re: check_snmp issue
Post by mcapra »
I've replicated this when checking a system's available memory:
[root@localhost libexec]# ./check_snmp -H 192.168.67.105 -P 2c -C welcome2 -o .1.3.6.1.4.1.2021.4.6.0
SNMP OK - 3565908 | iso.3.6.1.4.1.2021.4.6.0=3565908
With check_snmp, you should be able to define the unit yourself using the -u argument as a work-around:
[root@localhost libexec]# ./check_snmp -H 192.168.67.105 -P 2c -C welcome2 -o .1.3.6.1.4.1.2021.4.6.0 -u kB
SNMP OK - 3565908 kB | iso.3.6.1.4.1.2021.4.6.0=3565908kB
bmccarthy
Post by bmccarthy »
Thanks, mcapra. I'm glad someone else has now confirmed it. Seems like a bug to me. I'm aware of the -u switch and will most likely need to implement it. Thanks again.
Post by mcapra »
Sure thing! Your best bet in getting the problem fixed is to raise an issue on the github page for nagios-plugins:
https://github.com/nagios-plugins/nagios-plugins
Is it alright if we lock this thread and mark the issue as resolved?
bmccarthy
Post by bmccarthy »
Sure, mcapra. Lock and mark as Resolved. I will take your suggestion and raise the issue in https://github.com/nagios-plugins/nagios-plugins. Sorry for the delayed reply. Thanks again.
Post by dwhitfield »
Glad to hear we have an easy workaround. I am going to lock the thread. Please feel free to post again if you have you another issue. Thank you for using the Nagios forums!
