Backups Continually failing
peter.zanetti
Post by peter.zanetti »
We are experiencing some issues creating a good complete backup file. Every time we try we are left with partial directories that are failed backups, which are also taking up a lot of disk space. Is there anything known to cause this issue and if so is there a known fix?
Re: Backups Continually failing
Post by Box293 »
Can you please follow this article to run the database repair process as I believe you may have some database issues:
https://support.nagios.com/kb/article.php?id=24
This may take a while to complete. Once it has, please scroll back up through the history to make sure there were not any database errors (you may see an ndo2db error when stopping the service but this is ok).
This KB article explains your issue:
https://support.nagios.com/kb/article.php?id=514
peter.zanetti
Thank you for the feedback, we will look into this and follow up with the results. Thanks again.
bwallace
Post by bwallace »
You're welcome. We'll leave this thread open in the meantime, let us know of the outcome.
